ECU question
Old Apr 28, 2010 | 08:12 AM
Teamjupito's Avatar
Icon6 ECU question
I got a 93 civic hatchback and im putting a 90 LS into it and the mechanic said i could still use the 93 ECU and was wondering if thats true and will the car run right
Old Apr 28, 2010 | 08:38 AM
CivicSpoon's Avatar
Default Re: ECU question
Technically you can, but it's not a good idea to do it for a long time. The fuel and ignition timing maps will be for the SOHC 1.5 or 1.6L engine, and you'll be running a 1.8L DOHC engine, so the maps will be completely wrong. Eventually you will damage the engine, from running so lean (among other things). You should find a '92-'93 LS ECU, since it's such a similar engine and it's OBD1 so it will plug right into your car. Or get your stock ECU chipped with the base map for your new engine.
Old Apr 28, 2010 | 08:44 AM
speedooo's Avatar
hondaspoon is dead on
Old Apr 28, 2010 | 08:47 AM
Matt93eg's Avatar
X2!
Old Apr 28, 2010 | 10:05 AM
Teamjupito's Avatar
ok i also forgot to mention that the civic is automatic and im making it stick so regardless im better off getting the ecu. Would the 90 ls ecu work
Old Apr 28, 2010 | 01:24 PM
speedooo's Avatar
no
Free Man
Jan 4, 2019 06:05 PM
nolanator6
Apr 4, 2011 04:56 PM
Eclectia
Jun 29, 2010 12:26 PM
89civichatchback
Jan 18, 2003 07:58 AM
asianspeed
Nov 13, 2002 08:28 PM
