b16 , p28 , tune ???
Old Apr 27, 2010 | 09:49 PM
hellajdm333's Avatar
Default b16 , p28 , tune ???
running a b16 on a chiped p28 for long bad????......will a tune really help??? just has bolt ons!.......should i get cam gears befor a tune? or is it pointless with stock cams??? lookin for any input.....
Old Apr 27, 2010 | 09:55 PM
AKAViRiZ's Avatar
Default Re: b16 , p28 , tune ???
I'm Running a p28 on my b16 without a tune and its just fine, But a tune is recommended.
and when you do cam gears, shafts, etc, its also good just to be on the safe side.
Old Apr 27, 2010 | 10:20 PM
i was just wondering if i would benefit from a tune???? is the $300 worth it??? will i see a improvement???? be faster....???? should i get cam gears with stock cams??? a shop was tellin me i should get them befor we tune! i wasnt sure about that!....????
Old Apr 28, 2010 | 12:26 AM
Kidnkorner's Avatar
How do you know you are fine? Are you running a wide band? Is this a straight P28 or a chipped P28 with generic basemap?
Yeah, the benefit is your air fuel ratio will be dead on and you won't lean out causing the over expansion of your pistons scoring up your cylinders.
Skip the cam gears unless you want feel the need to put money in the retailers register.
If you chose to tune what engine management are you going with?
Old Apr 28, 2010 | 01:00 AM
i dont know yet?? chrome probably???
Old Apr 28, 2010 | 03:13 AM
azandford's Avatar
yes a tune is definently worth it chrome is a decent problem and probably your best bet with your current setup dont get the cam gears unless your planning on swapping in some better cams look into some gsr's there cheap and will add as much hp as some other bolt ons
Old Apr 28, 2010 | 03:26 AM
civicv's Avatar
Have you dyno'd it yet? I would at least dyno and see what kind of numbers you are running. Try and get on a group day, 2-3 pulls shouldn't cost you to much.
Old Apr 28, 2010 | 04:58 AM
dpetro1's Avatar
if you already have a chipped ecu then you should at least get a b16 map. you dont have to get a full tune, just have one of the tuners on this site burn you a chip. should be $30 max
Old Apr 28, 2010 | 10:24 AM
AKAViRiZ's Avatar
My p28 is chipped and Base mapped for a b16.
Old Apr 28, 2010 | 10:35 AM
98civdx's Avatar
Master Detailer
A base map really doesnt mean much, your air fuel can still be off.
A chiped and tuned p28 is deffinetly worth it, the only way to get the true power is to be tuned.
Old Apr 28, 2010 | 02:48 PM
yeah i think i will! around here its about $300 for a tune! gsr cams...??? what kind of #s we lookin at doin that swap???? thanks guys for all the good info!
Old Apr 28, 2010 | 10:37 PM
anyone??? anyone runnin gsr cams in b16???
twotonecivic
Engine Management and Tuning
Dec 28, 2011 07:10 PM
909ej
Dec 21, 2010 09:33 AM
hellajdm333
Apr 28, 2010 04:15 AM
ivan93egreppin210
Dec 12, 2008 05:51 PM
erasable180
11
Mar 11, 2006 08:57 PM
