p30 vs p28
Old Dec 11, 2008 | 11:33 AM
ivan93egreppin210's Avatar
Default p30 vs p28
my buddy just got a p28 for his b16 swap. will the p28 run the b16 ok or are the base maps too different? i figured since they are both 1.6ltrs, they might be similar. he will be chipping his p28 in a few weeks. how will the car drive with a virgin p28? should he just get a p30? his car is a 93 civic dx
Old Dec 11, 2008 | 11:29 PM
fourthgenhatchB17's Avatar
To me it's obvious that the P30 is the correct ecu for a stock B16. I would run that. i just so happen to have a P30 available too
Old Dec 11, 2008 | 11:46 PM
doc's Avatar
doc
Or, when he plan to chip it anyway, he should chip it right now - at least with a stock P30 program. If you only need to fire up the engie to check everything after the swap and bleed the cooling system, i think the p28 will do it, too. Just don't beat it with the wrong ECU or wrong code.
Old Dec 12, 2008 | 05:43 AM
Dualcampro's Avatar
word...
Old Dec 12, 2008 | 05:51 PM
batallic's Avatar
p28 = SOHC, redline 7200, vtec 5300,
p30 = DOHC, redline 8k,
totaly different
TheRobotSpy
Oct 11, 2009 08:02 PM
EJ SIR
14
Feb 19, 2009 01:55 PM
erasable180
11
Mar 11, 2006 08:57 PM
B6teen
Apr 25, 2005 01:39 PM
