What whp numbers you are making on a stock sleeve ls vtec turbo?
What whp numbers you are making on a stock sleeve ls vtec turbo? I am curious what numbers you are making out there. Please list fuel and other mods like block guard, eagle rods,ect...
Plently of people have had stock sleeves up to 600+whp with higher octane. I would say anything over 500+whp is when you would want to start thinking about sleeving.
I will be more specific, Im planning on running e85. I have 1200cc injectors and a 255 lph fuel pump so i have the capibilities to feed it. I'm just wondering what numbers people are actually putting down
500 is safest reliable whp on stock sleeves. more can be made but they wont last, as far as how long they will or will not last there is no standard, they crack when they crack
My setup last year with 1000 I.d. Injectors 93 octane 480hp stock sleeves. Motor is still running to this day in another vehicle no problems.
Typically, 400-450 whp is fine. Ultimately, what one guy said is correct, "they will crack when they crack." All OEM parts from those engines are getting old, especially the late 1980s into the 90s. In the future, I plan on pushing mine a bit past 500, but "plan on pushing mine" isn't synonymous with "will work just fine." Tread at your own risk and be prepared if it fails.
my buddy is trying to build a 12 sec street car on a budget so a gsr and sleeveing is out of the question. And he is not a great driver so he is gonna need more power than most to run the same times
