1 wire to 4 wire conversion
I need to do this conversion and wouldnt mind if i can get a write up with pics plz..hlp a brotha out..I tried google but i keep getting different versions
I have a 90' ef wit a y7 but will be swapping a y8 in soon..and im using my stock a6 ecu(need to instructions for the a6 ecu and y7)
thanks
thanks
What are you trying to say?
You are preparing for the D16Y8 to go in with a different OBD?
What is the reason you need to do this conversion? You do not need to do that if you ar going to be running the D16A6 ECU as they only need an 1-Wire O2 sensor.
well pretty much aiming for better mileage..i was told the 4-wire o2 give better gas mileage..
Dee_333
May 20, 2011 03:20 PM
