1997 civic lx sedan, 1.6 liter sohc nonvtec. please help with knocksensor replacemnt
Old Apr 27, 2010 | 11:27 AM
xpdude's Avatar
Default 1997 civic lx sedan, 1.6 liter sohc nonvtec. please help with knocksensor replacemnt
so it is pinging and i want to replace the knocksensor. i found it, but how does it come off??? there is a rubber boot over the sensor and bolt area where it goes into the block. how does it come off to unscrew it?>
Old Apr 27, 2010 | 01:31 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 1997 civic lx sedan, 1.6 liter sohc nonvtec. please help with knocksensor replac
You don't have a knock sensor on the D16Y7. The sensor you are trying to unplug I believe is the oil pressure sending unit that measures oil pressure to send signal to the dash oil light and is covered by a rubber boot.
Old Apr 27, 2010 | 01:37 PM
xpdude's Avatar
no knock sensor? what adjusts the timeing automaticly when you go? is their an advance mech on there somewhere? it pings when i put in 89 octane and 97 octane less pinging. trying to fix the pinging issue before i burn a piston. no valve tickage.
Old Apr 27, 2010 | 02:53 PM
Technical Hero
Have you messed with your distributor or checked your ignition timing?
Jaz760
Apr 7, 2012 06:37 PM
joedr
Nov 9, 2008 12:11 PM
one-cam
22
Feb 28, 2008 07:37 AM
h22_crx
Jan 19, 2007 03:06 PM
integramic
Sep 15, 2004 05:52 AM
