crazy bogging when motor is cold...
Old Apr 26, 2010 | 12:11 PM
mikej94civex's Avatar
Default crazy bogging when motor is cold...
i figure plugs and wires r needed but i wanna c what u guys say before i go spend money i don't
have lol. ok, when i drive the car under operating temp (still cold, not even on white line yet) if i give it any
more than 50% throttle it boggs crazy and acts like it's missin real bad, also i noticed this occur more
often when it's raining out, once the car is warm it runs fine...
Old Apr 26, 2010 | 12:41 PM
blown_ss's Avatar
Default Re: crazy bogging when motor is cold...
then let the car warm up. i do it every time before i drive the car. problem solved.
Old Apr 26, 2010 | 01:13 PM
really? you my friend are a moron! letting the car "warm up" has nothing to do with it, if u wanna search
for urself u will find a vehicle, unless in a sub-zero climate only needs 30-45 seconds to be safe. driving
is actually the best way to warm up an engine, taking it easy of course...anyways can someone with some help
not a nooby *** give me an idea as to what's wrong?
Old Apr 26, 2010 | 01:14 PM
if this helps any, the "bog" is only in gear with load on the motor, it revs fine in neutral..
Old Apr 26, 2010 | 01:16 PM
and i DO let the car sit once started in idle for at least 2 minutes before i drive unless i'm in an absolute hurry, in case that matters to anyone else
Old Apr 26, 2010 | 02:21 PM
gibsanez's Avatar
Do you have a CEL
Old Apr 26, 2010 | 03:04 PM
eh9deux's Avatar
What kind of intake you got on? Maybe you sucked in a really, really small amount of water in the engine?
Old Apr 26, 2010 | 03:10 PM
VTECROAR96typeR's Avatar
Originally Posted by gibsanez
Do you have a CEL
WTF are you doing here? Go back to your pos GDD forum douchebag. JK
Oh by the way op I have the same issue, my motor will also bog out if i leave with out letting the car get at least 1 heat line. when i do leave with out letting the car warm up, i just granny shift untill the car warms up as i go.
Old Apr 27, 2010 | 03:15 AM
gibsanez's Avatar
*Really really small amount* wouldnt do anything, ever hear of water injection on high boost engines?
Old Apr 27, 2010 | 06:14 AM
GRANT!'s Avatar
hmm... check my post out. i may be having the same problem, mine being more severe though
Old Apr 28, 2010 | 12:12 PM
well, there was no cel at the time, it happened 3 different occasions up till my post...i have an aem short
ram, i doubt any water sucked up but idk for sure, um the cel came on last nite outta nowhere, i reset the ecu
and it went away, no i didn't run the jumper for the code before i reset it. the light hasn't come back on yet
so idk bout that...so back to my theory would plugs cause this?
Old Apr 29, 2010 | 01:27 AM
gibsanez's Avatar
Why the hell wouldn't you have checked the code instead of aimlessly guessing again like you are now?
Old Apr 29, 2010 | 10:01 AM
well like i said ^ the "bogging" has happened a few times before the code, it happened the first time about a mth
ago...i didn't feel the code was relevant to the issue. From what i've gathered from searching it's either:
*plugs
*fuel supply system, i can't find anything else thru searching, so i'm gonna change the plugs and go from ther
i guess, if i get a cel again for sure i'll run the code and bb..thanks
bossm
Jan 22, 2009 04:31 PM
Jmunk
Jun 4, 2004 02:19 PM
vtec69
Dec 16, 2003 04:21 PM
vtec69
Dec 16, 2003 09:27 AM
vtec69
Dec 16, 2003 07:58 AM
