crazy bogging when motor is cold...
i figure plugs and wires r needed but i wanna c what u guys say before i go spend money i don't
have lol. ok, when i drive the car under operating temp (still cold, not even on white line yet) if i give it any
more than 50% throttle it boggs crazy and acts like it's missin real bad, also i noticed this occur more
often when it's raining out, once the car is warm it runs fine...
Re: crazy bogging when motor is cold...
for urself u will find a vehicle, unless in a sub-zero climate only needs 30-45 seconds to be safe. driving
is actually the best way to warm up an engine, taking it easy of course...anyways can someone with some help
not a nooby *** give me an idea as to what's wrong?
and i DO let the car sit once started in idle for at least 2 minutes before i drive unless i'm in an absolute hurry, in case that matters to anyone else
WTF are you doing here? Go back to your pos GDD forum douchebag. JK
Oh by the way op I have the same issue, my motor will also bog out if i leave with out letting the car get at least 1 heat line. when i do leave with out letting the car warm up, i just granny shift untill the car warms up as i go.
well, there was no cel at the time, it happened 3 different occasions up till my post...i have an aem short
ram, i doubt any water sucked up but idk for sure, um the cel came on last nite outta nowhere, i reset the ecu
and it went away, no i didn't run the jumper for the code before i reset it. the light hasn't come back on yet
so idk bout that...so back to my theory would plugs cause this?
ago...i didn't feel the code was relevant to the issue. From what i've gathered from searching it's either:
*plugs
*fuel supply system, i can't find anything else thru searching, so i'm gonna change the plugs and go from ther
i guess, if i get a cel again for sure i'll run the code and bb..thanks
bossm
01-22-2009 04:31 PM
