changed the tranny now fuel pump wont start?
Old Apr 25, 2010 | 04:38 PM
corked1260's Avatar
Default changed the tranny now fuel pump wont start?
i changed the clutch in my d16z6, but when i was dropping the tranny i broke the wire that read for the speedo, it a 3 pronged gray clip.i drove the car with the clip brokedn and just had no speedo, then i trided to just put the wires back on using small femal butt clips and then it just cranked and got no fuel. the fuel pump is not primming, has a code but does not flash when jumped with the wire across the brown and green/white wire, totally lost i sure someon knows this... thanks
Old Apr 25, 2010 | 04:45 PM
burnykawizzle's Avatar
Default Re: changed the tranny now fuel pump wont start?
go to your fuel pump main relay... look for the yellow/green wire yellow being the main color and green is the strip color... cut it and strip the coat off abit then connect it with a connect to you optional underdash fuse box power source... if it still doesnt work then get under your car and check to make sure you connected all your wiring correctly take off the ground from the battery wait 2 mins then plug it back on before you do the fuse box thing i covered in this posting
Old Apr 25, 2010 | 05:07 PM
OhMy-EK9's Avatar
lol i had the same problem check ur ground by the thermostat on the engine harness i had the same proble it pissed me off
Old Apr 25, 2010 | 05:21 PM
corked1260's Avatar
i just did what you told me to do and the fuel pump did not prime, i then jumped terminals 5 and 7 on the main fuel pump relay and read for voltage at the fuel pump power plug ( 3 pronged gray clip) and got 6.55 volts.... chiltins manual said to it should have 12.25..
i also checked the thermostat ground.. and got nothing.
Old Apr 25, 2010 | 05:28 PM
put a ground from your transmission to the car body... something went wrong when you did the wiring again... disconnected everything and then reconnect
Old Apr 25, 2010 | 05:30 PM
corked1260's Avatar
would that cause the drop in voltage to my fuel pump, because it ran unitil i tried to re hook up the speedo plug
Old Apr 25, 2010 | 05:32 PM
maybe not really sure but what i suggest if take off all the wiring, clean up the plug and then reconnect. put a ground from the transmission to the engine bay. disconnect the battery then reconnect. you must have a weak ground!!!
Old Apr 25, 2010 | 05:33 PM
also check the ground from under the dash.... make sure all the grounds are screw in tight
Old Apr 25, 2010 | 06:01 PM
corked1260's Avatar
i will do all that tomm, i ahve been working on this sense like 9 this morning.... i will post up with updates as soon as i do them..
Old Apr 26, 2010 | 12:32 PM
corked1260's Avatar
bump for anyone with ideas?????
Old Apr 26, 2010 | 01:31 PM
Former User's Avatar
Clean and tighten the thermostat housing and transmission ground connections.
RICE POLICE SIP
Apr 21, 2010 03:26 PM
on-site ej1
Apr 3, 2009 09:30 AM
FW_EJ8
Dec 17, 2007 06:03 PM
SuicideSlide
Feb 17, 2005 03:09 PM
hatchback_al
Oct 26, 2004 10:00 AM
