Need help! Gauges do not work
Old Apr 25, 2010 | 09:50 AM
Sosa22's Avatar
Default Need help! Gauges do not work
My gauges do not work for some reason what could it be? it doesn't tell me how much gas I have or speed or RPM not Even Temp but They do light up and the turn signal indicator works but thats it. Help anyone?
Old Apr 25, 2010 | 10:02 AM
RICKSAUTOMOTIVE's Avatar
Default Re: Need help! Gauges do not work
sounds like a fuse or somethin. theres a 15 amp wire that goes to the fuse box i believe under the dash but it could be the under hood box and that runs most of the cluster. see if thats bad. if not you may have loose connections or at worst ab bad ecu. never heard of a cluster going out though like yours has. but its still possible you cluster is bad. tell us more about your car so we can post more. the 15 amp wire is for a car i just worked on and that was the issue. your electrical circuit may be a little different
Old Apr 25, 2010 | 10:05 AM
Sosa22's Avatar
Well its a 94 integra GS sedan I just bought it 2 days ago the gauges didnt work when I bout it the guy said he thinks its a fuse but if it was a fuse why it still light up and plus I dont know where the fuse is or which fuse it is.
Old Apr 29, 2010 | 05:23 PM
IMPORTMyth01's Avatar
its a fuse trust me, had the same problem...its called "Back Up Light" think its a 10amp next to the headlight fuses.
Old May 2, 2010 | 01:15 AM
Sosa22's Avatar
You sure because i have checked every fuse and I took my cluster out and the screen is cracked what if the guy i bought it from roled the miles back on purpose and didnt tell me and that messed up the whole cluster? is that possible
Old May 4, 2010 | 08:30 AM
well this is a 2 day old thread...did you get the issue fixed? PM me if you need to and lets see if we can help you out
93_BB2_Prelude
Sep 30, 2013 05:52 PM
agustintorre
Sep 14, 2012 06:55 PM
michael-crxsi
Mar 7, 2010 02:31 PM
88aeFC3S
Aug 4, 2008 12:41 PM
civicsiboosted
Sep 26, 2002 09:30 AM
