dizzy problem??
Old Apr 24, 2010 | 04:53 PM
90edhb's Avatar
Default dizzy problem??
hello everyone
i have a 91 ls special..everythig stock
my problem is; it bogs between 3300 and 4000 rpm
i changed the plugs, cap, rotor and fuel filter thinking that might fix the bogging but still does it
what would cause the problem? would it be the dizzy?
any help would be great
thank you
Old Apr 27, 2010 | 08:07 AM
90edhb's Avatar
Default Re: dizzy problem??
mornig bump
i need some help please
what could couse this to happen?
it loses power between 3000 and 4000
maybe fuel pump? or dizzy?
please help i wanna drive my baby lol thnk you
Old Apr 27, 2010 | 10:58 AM
90edhb's Avatar
anybody knows what i should do or check?
please help out a fellow Da owner
Old Apr 27, 2010 | 06:17 PM
ryan_integra's Avatar
have you checked your timing?
Old Apr 27, 2010 | 06:18 PM
or changed your air filter?
Old Apr 27, 2010 | 06:39 PM
olskoolcelica's Avatar
did u turn the dizzy?? it moves with time or when people mess with it causin it to misfire chek the haynes manual
Old Apr 27, 2010 | 08:38 PM
RedEG2's Avatar
try and find a diff dizzy so you can narrow it down to if its the dizzy or not. if its the dizzy then its either the ICM or coil
Old Apr 28, 2010 | 05:03 PM
90edhb's Avatar
timing is dead center and change the air filter
check all the bolts on dizzy; all are tight
found me a dizzy and still did the same thing...im thinking fuel pump
Old Apr 28, 2010 | 06:11 PM
EHondaJDM's Avatar
Shouldn't be the pump if its only at a certain rpm, ur positive the timing is right?
Old Apr 28, 2010 | 07:16 PM
91tegjosh's Avatar
when i unplug my tps it did that i would try that so mabie a new tps or pull ur TB off and cleaned the fast idle thermo valve and the idle air control valve and in side fitv it wasnt screwed in right so try that stuff
Old Apr 29, 2010 | 07:53 AM
90edhb's Avatar
timing is dead on
ill try that today
thanks to all for the help
capm.stabahoe
Dec 27, 2008 06:17 PM
willseghatch
Feb 21, 2008 11:34 AM
Jorsher
Feb 23, 2006 09:27 PM
SlowSOHC-T
Nov 25, 2005 08:56 AM
