mild gsr na build dyno results
Old Apr 23, 2010 | 12:22 PM
HondaManMike's Avatar
Default mild gsr na build dyno results
hey guys, i recently built and dyno'ed my car and im pretty happy with the results. any input would be appreciated as this is my first na project
mods are as follows
96 integra gsr, 160,xxx on bone stock bottom end
stock head, removed .020 relapped valves, new seals
skunk2 pro springs and retainers
skunk2 tuner 2 cams
skunk2 pro series intake manifold
blox 68mm throttle body
home made 3 inch cai
rc 310cc injectors
hytech replica header big tube
3 inch exhaust vibrant flatblack muffler
hondata s300
results
193 whp 124 ftlbs torque
Old Apr 23, 2010 | 12:23 PM
Default Re: mild gsr na build dyno results
sorry about the crappy pics
Old Apr 23, 2010 | 03:12 PM
OH_1fstgsr's Avatar
On a bone stock bottom end. 10:1 compression. Really good numbers. A/F can use a little more clean up.
Old Apr 23, 2010 | 03:15 PM
S2Integra's Avatar
Almost exact same setup as mine but I have 184 whp and 124 ft/lbs. You have bigger piping than I do is all.
Old Apr 23, 2010 | 03:24 PM
System Lord's Avatar
Old Apr 23, 2010 | 03:48 PM
C-Rex1021's Avatar
My plan in terms of the head, but I wanted to do ITR pistons. Bump for some good numbers
Old Apr 23, 2010 | 03:49 PM
redGSRguy's Avatar
Not bad! Must be a world of difference from before. My gsr build did 205/130 with blox c's and jdm itr pistons and it was WAY more fun than stock =P.
Old Apr 23, 2010 | 03:51 PM
vtaker's Avatar
nice numbers. it really shows the potential of these vtak engines
Old Apr 23, 2010 | 08:16 PM
thanks guys, i was pretty happy with the numbers, more than i expected for sure. still not enough though what else should i do?? p73 pistons, sk2 pro3, balanced and rev to 10 im thinking
Old Apr 24, 2010 | 02:08 AM
artin01's Avatar
thats very good.
Old Apr 24, 2010 | 04:11 PM
94VTEC2TONE's Avatar
not bad numbers looks like the graph is a little choppy though
Old Apr 24, 2010 | 05:36 PM
i was having some ignition breakup in the high rpms. i need to get rid of the msd and stick with stock
Old Apr 25, 2010 | 07:50 AM
ohh ok. ya msd just seems to blow on our cars
Old Apr 25, 2010 | 09:35 PM
yeah, the factory honda ignition systems are really hard to improve upon, i figured id give msd the benifit of the doubt and try it out, turns out it was a bad idea
Old Apr 26, 2010 | 09:23 AM
slateEKsi's Avatar
hows your gas mileage with this setup ?
Old Apr 26, 2010 | 12:28 PM
Schister66's Avatar
Man U FTW
The tune leaves something to be desired, but you made good power regardless
Old Apr 26, 2010 | 09:14 PM
yeah, there is more in it, the fuel mileage is really good actually, i got 28mpg last tank and i was beating on it. as far as the cams are concerned, i dont reccomend them with anything less than 12:1 as they dont make any power until after 7k and start trailing off around 8500. this is a horribly useless powerband and i was really expecting more useability
Old Sep 26, 2010 | 02:13 PM
Pinner13's Avatar
i know bim bringing this back up but is 68mm to big?
V-SPEC 1
25
Jul 19, 2016 10:05 AM
Lozano1991
May 24, 2013 07:56 PM
TnC
43
Sep 24, 2012 06:52 PM
92cxturbo
17
Oct 18, 2010 09:08 AM
turbojdmsol
12
Jan 17, 2010 02:44 PM
