Distributor won't unbolt
Old Apr 23, 2010 | 11:16 AM
kitt's Avatar
Default Distributor won't unbolt
I'm following this guide on HOW TO: change a distributor o-ring but none of the bolts on the distributor will unbolt. I also tried WD40. I'm using a 12mm socket wrench. Additionally, I only see two bolts on my distributor (the top bolt isn't there). Ideas?
Car: Honda Accord 1998 LX
Old Apr 23, 2010 | 11:21 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Distributor won't unbolt
PB Blaster.....
Old Apr 23, 2010 | 11:22 AM
RICKSAUTOMOTIVE's Avatar
sounds seized. let the wd-40 soak for a few minutes. use a 6-point socket so you dont strip the bolt. see if the missing bolt is broke off and thats why its missing. the old owner may have broke it. or a shop who didnt tell you anything or fix it
Old Apr 23, 2010 | 11:29 AM
ilikehonda's Avatar
get a breaker bar ; )
Old Apr 23, 2010 | 12:25 PM
kitt's Avatar
OK, got the damn thing to budge. I guess the WD40 finally kicked in. Thanks guys
Old Apr 23, 2010 | 05:13 PM
slomofo's Avatar
GDD Member
For future reference, pick up a set of 6 point wrenches and they'll come off much easier next time.
Old Apr 23, 2010 | 05:44 PM
CuteAccord's Avatar
There are three bolts total, you're probably having a hard time finding the one underneath.
Old Apr 23, 2010 | 06:13 PM
jdmwannabee's Avatar
this + stop using wd-40! there's pb blaster, liquid wrench, etc etc...
Old Apr 23, 2010 | 07:36 PM
kitt's Avatar
My socket wrench has a 6 pt head. There was only 2 bolts, the top one wasn't there. Two on the both sides on the bottom where there though. Oh, and WD40 has a cool nozzle
Old Apr 23, 2010 | 11:08 PM
BracedEunos's Avatar
Buy a compressor. Use impact to loosen. EOS.
85civic
Aug 14, 2004 01:38 PM
85civic
Aug 14, 2004 12:27 PM
98R-1144
Jun 28, 2004 05:21 PM
typeeg
Jun 8, 2004 08:09 PM
