Whats the upper 5 point hex bolt on trans?
Old Apr 22, 2010 | 01:43 PM
FlewByU352's Avatar
Default Whats the upper 5 point hex bolt on trans?
On the transmission theres the lower 4 point for the drain, the bigger 4 point for the fill level, and then the 5 point hex for what? Can you fill it from there?
Old Apr 22, 2010 | 03:53 PM
DAintegraGSR's Avatar
Default Re: Whats the upper 5 point hex bolt on trans?
i belive that would similar to a freeze plug on the block... i know it has not relation to maint or anythinfg like that.. hth
Old Jul 11, 2010 | 06:31 AM
burfy's Avatar
I thought #14 was the fill port and #13 was just the port to access the snap ring to release the case from the bearing..
Old Jul 11, 2010 | 07:49 AM
follie gatts's Avatar
18 fill 12 drain?
Old Jul 11, 2010 | 03:57 PM
steveo135's Avatar
I'm thinkin this.
Old Jul 11, 2010 | 05:02 PM
skracer13's Avatar
12 is to drain and 18 is to fill. 13 and 14 are used for dismantling the transmission. you wont get far trying to fill @14.
Old Jul 11, 2010 | 10:06 PM
vtaker's Avatar
this
Old Feb 12, 2011 | 02:30 PM
burfy's Avatar
Haha, whoops.. It's possible to fill at #14 cuz that's where I always have filled from I only filled to what ever it called for - which explains why it never came back out lol
Old Feb 13, 2011 | 10:28 AM
bks84's Avatar
Loved
so much wrong info in this thread...
12 and 18 are your fill/drain points.
Not entirely sure what 14 does. but it is not your fill/drain point.
.inbou
Nov 6, 2009 01:42 PM
lamboextreme
Sep 4, 2007 10:24 PM
dlszrfn
Mar 30, 2005 08:01 PM
mnbv
Aug 1, 2004 11:51 PM
chico_rahman
Apr 15, 2003 04:23 PM
