Difference between OBD1 and OBD2 GSR Lower Timing Cover
Old Apr 22, 2010 | 11:14 AM
CivicTT's Avatar
Default Difference between OBD1 and OBD2 GSR Lower Timing Cover
so ive searched high and low and cant figure out the difference between the OBD1 and OBD2 B18c1 lower timing cover...my only thought would be something for the CFK sensor thats not located on OBD1 motors. Can anyone tell me the difference? Im in the market for one but dont know which one to buy
Old Apr 22, 2010 | 01:33 PM
mouab18c1's Avatar
Default Re: Difference between OBD1 and OBD2 GSR Lower Timing Cover
I think the covers are the same. If I remember right I have a 97 GSR lower timing belt cover on an obd1 block.
Old Apr 22, 2010 | 01:40 PM
racebum's Avatar
slight cutout for the cfs sensor
the mid and upper pieces are the same
obd2 will fit 1 but 1 will not fit 2 if you still have the cfs
Old Apr 22, 2010 | 07:54 PM
CivicTT's Avatar
so i do need an OBD2 cover...thanks for the info guys
Old Apr 22, 2010 | 08:47 PM
mouab18c1's Avatar
If you're going to be running an obd1 ecu then no you dont need the CKF sensor
Old Apr 23, 2010 | 12:36 AM
RICKSAUTOMOTIVE's Avatar
agreed
Old Apr 23, 2010 | 05:09 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you run an OBD2 oil pump (sometimes called an ITR oil pump even though there is no such thing), I believe you have to either use an OBD2 lower timing belt cover, or modify the OBD1 cover.
Old Apr 23, 2010 | 06:24 AM
CivicTT's Avatar
I understand if im running OBD1 i dont need a CFK, however ive chose to go OBD2, keeping it with the car thats OBD2, the entire motor was pulled out of an 01 GSR so i do have the OBD2 oil pump....so it IS possible to modify the OBD1 cover in the event i cant find an OBD2?
Old Apr 23, 2010 | 12:21 PM
mouab18c1's Avatar
You'll just have to cut a gap out of the obd1 cover so that the wires can pass through.
Old Jul 12, 2010 | 01:29 PM
Frankacura's Avatar
Nice infos.
Im going to swap from OBD1 pump to OBD2 next week
So i will not looking for an obd2 cover anymore.
The OBD2 oil pump is called ITR pump cuz there is only 1 pump for the OBD2, Vtec or not...
MikeD21
Feb 12, 2019 08:30 PM
blackcherry
Jun 16, 2014 05:06 PM
BIG RICH
Jul 3, 2006 09:31 AM
AsianMullet
Jan 22, 2005 05:21 PM
TypeGSR196
Feb 10, 2004 12:08 PM
