Turbo clearance help anyone
So have a four door 91 Acura integra ls/v-tec gsr intake mani and head ok my problem is that my turbo runs into my cross member now that sounds like an easy fix right just take Out the crossmember but doesn't that add all the stability in the front end is there any aftermarket replacement besides a H- brace I just don't know wat to do at this point just some suggestion from some of those turbo people out there
ive had friends that just cut nice chunks out of the crossmember, but yes the crossmember is for stability itll wack out your alignment if you remove it, almost positive.
as for aftermarket replacements i have never heard of any
Well just to inform you, There are a few after market company's that makes racing cross member / traction bars, The only thing is that they are not cheap, I paid 400 for mine from full-race.com.. And it gives you plenty of room to do what ever you please and provides better traction and stops wheel hop , I had the same issue with my turbo and my down pipe and i didnt really trust cutting the stock cm, Plus im trying to save as much weight as possible.. Google it first u might find some cheaper just remember not all come with the front mount option.. good luck
http://www.full-race.com/catalog/ind...ath=22_712_774
Thats the link to the c/m ^, You dont have to buy it but this is the best design you can get for a DA
Traction bars are great for just about everybody.
