Fuel pump For H22 Civic
Old Sep 10, 2002 | 07:06 PM
SilverEk3dr's Avatar
Default Fuel pump For H22 Civic
Ok....I have had my H22 for a while now. But sometimes when I get on it My car seems to hesitate in high RPM's. It seems that it is running out of fuel or running lean.
Now my question is: Can a prelude fuel pump be used in a civic (bolt-in). Or should I just go ahead and buy aftermarket?
Thanks
Mark
[Modified by SlvrEj6Dx, 4:06 AM 9/11/2002]
Old Sep 10, 2002 | 08:59 PM
heiyu's Avatar
Default Re: Fuel pump For H22 Civic (SlvrEj6Dx)
it can i have one in my car right now but its a pain in the *** to do. also the pickup is located higher so you need to keep more gas in your tank. But it does work. But i highly recomend getting a aftermarket fuel pump.
Old Sep 10, 2002 | 10:30 PM
Jonathan_ED3's Avatar
Default Re: Fuel pump For H22 Civic (heiyu)
why not get an OEM Type R fuel pump?
Flows more than your stock one, is a direct fit.
b18c5 and h22a have about the same fuel requirements (stock for stock). If you're pretty much stock, I'd say go for the Type R pump.
I'm going to.
Old Sep 11, 2002 | 10:52 AM
ITR632's Avatar
Default Re: Fuel pump For H22 Civic (hot_EG)
I used the Walbro 255, It works great.
Old Sep 11, 2002 | 12:32 PM
H22EK's Avatar
Default Re: Fuel pump For H22 Civic (ITR632)
if i were you i would just get a walboro, especially if you are do a bunch of mods, you don't want to run to lean, thats what i did, plus you are set if you ever wanna get into some burley **** as far as f.i.
Old Sep 11, 2002 | 04:27 PM
Default Re: Fuel pump For H22 Civic (H22EK)
Doh!.....I didnt think of that. Anything will outflow my DX pump. I am gonna stay N/a and not go crazy on Comp./cams.....etc, and the Type R pump will probably do the trick real nice.
Thanks for the help guys..
[Modified by SlvrEj6Dx, 1:31 AM 9/12/2002]
Old Sep 12, 2002 | 08:02 AM
Jason kiDD's Avatar
Do you have any more pics of your car. From the avatar it looks really nice..
And I would go with Walbro..
Old Sep 12, 2002 | 06:42 PM
Default Re: Fuel pump For H22 Civic (C5_ALLMOTOR)
Yeah... check em' out
http://www.geocities.com/whiterabbit...s/EK_pics.html
and some more of the Car and one of the broken engine mount...
My Avatar
With Rota slipstreams
The Dead Stock Ek driver side mount (currently replaced with a placeracing mount)
The Prelude shifter installed
Mark
[Modified by SlvrEj6Dx, 4:06 AM 9/13/2002]
Old Sep 12, 2002 | 07:05 PM
Jason kiDD's Avatar
Nice pics. Did you take it to the track yet to get some base times..
[Modified by Jason kiDD, 11:08 PM 9/12/2002]
Old Sep 12, 2002 | 07:11 PM
Default Re: Fuel pump For H22 Civic (Jason kiDD)
No...no track times yet. I raced my friends turbo eclipse that has 300 whp (and runs high 13's) I was right there with him till 3rd when he pulled a little (but that was the first time I got to race. So I might have been able to do better) I was running completely stock, with open header. So I didnt feel bad at all.
4.6 Mustang Killa Ha ha
I'm waiting on my Obd2 p13 to get to my house. I had my P5m done so that it would run without the Immobilizer, and its screwed (Iab's arent working...along with EGR....etc...) CEL is on constant and wont blink out codes. So its gone
Mark
[Modified by SlvrEj6Dx, 4:17 AM 9/13/2002]
Old Sep 13, 2002 | 05:24 AM
Jason kiDD's Avatar
I see, and what kind of shift assembly is that.. Looks weird.. hehe
Old Sep 13, 2002 | 02:54 PM
97+ prelude shifter
Old Sep 13, 2002 | 06:24 PM
Jason kiDD's Avatar
Cool. Nice pics and swap. When I am on the road I will have more pics of my setup and such.. Enjoy the h22 power..
Old Sep 13, 2002 | 07:05 PM
SilverEK's Avatar
Have you had any reliability issues with the axels, I heard that with that swap your axels can break easily due to the weight is this true at all or is it all fiction!
Old Sep 13, 2002 | 09:02 PM
racecarpete's Avatar
Default Re: Fuel pump For H22 Civic (SilverEK)
This beleif began for a number of reasons. First off obviously, the h22 is a bigger engine so the weight is a concern but the reasoning for axle breakage was poor mount design and engine placement putting stress on the axles. The definite example is place racing . Secondly, the lude axles are too long for the civic and created binding so people were using teg axles which didn't exactly match up properly. To remedy this problem, the current axle combo of teg outer shaft and accord intermediate shafts seem to be holding up well. And lastly some people were dropping the car too low and putting stress on the axles. Almost all these problems have been solved and if you are still worried bout axles, just get some driveshaftshop.com axles or something else with a lifetime warranty.
Old Sep 13, 2002 | 09:03 PM
97+ prelude shifter
Does the stock console not fit over the prelude shifter?
Old Sep 13, 2002 | 10:01 PM
Default Re: Fuel pump For H22 Civic (SilverCivic2k)
So far I only had one issue, and it was because I didnt put the prelude inner joint on the Teg. axle other than that I rag the **** out of my car, and havent had any problems.
And yes the prelude shifter will fit under the center console and you cant even notice its there (and you can even kep your cup holders)
Mark
Old Sep 18, 2002 | 09:03 AM
EK22Tim's Avatar
WOW, how'd you keep your cupholders? Mine was already installed in my car, looks EXACTLY like y ours, but the cupholders are pretty well hacked. Did you move the shifter back at all?
Old Sep 18, 2002 | 11:24 AM
MPower332TI's Avatar
Default Re: Fuel pump For H22 Civic (mitsuman90)
hum...nice silver dx...i have a 97 dx coupe...we just lowered my motor in last night..jdm h22..i have one problem though..my damn t brackett mount in the back does not line up with the rear mount at all..its like 3 inches or so higher than the mount is....anyone got any tips on this...?? at first i attached the rear mount first but then when u raised the motor to line up the side mounts the damn intake manifold would smash into the firewall...so i undid it and now i have both side mounts attached...its a place racing kit...also the damn alternator is very close to the headlight...ghey ****...im sorta frustrated..that damn rear mount is pissing me off.i stayed up till like 4:30 last night working on the damn thing..maybe we can get it fixed tonight....i got my motor form hondamotorsonline and it was very clean...i thing he might have gave me the wrong tranny t bracket though...who knows...any help would be awesome..heres a pic of the motor.
Old Sep 18, 2002 | 06:46 PM
Jason kiDD's Avatar
Default Re: Fuel pump For H22 Civic (jDmDxTuRd)
lol I had someone stand on the motor to get the rear mount in. It was a pain in the ***. Had to get a big as metal pipe too just to shift the motor away from the firewall so it would touch.. You just have to take your time. What helped too is thta we took off the driver side mount and put it in the bracket first then jacked up the motor to meet it ...
Ddogz15
Oct 1, 2004 05:23 AM
fastwanabe
Jul 9, 2003 04:03 AM
bb6h22a
Mar 14, 2003 10:06 AM
