speedodometer problem
Old Sep 10, 2002 | 06:46 PM
CoolKat's Avatar
Default speedodometer problem
for soem reason my speedodometer isnt working in my car. could it be the speed sensor or no? i have a95 civic cx hatchback with a gsr gauge cluster and an integra dash. i'm pretty sure i wired everything up correctly cause all of my signals and lights work. i replaced all the fuses and still dont work. also the rpms and voltage dont work either. any help would be great. thanks
Old Sep 10, 2002 | 07:19 PM
dogpile5's Avatar
25 Year Member
Default Re: speedodometer problem (CoolKat)
there's about a zillion things it could be...i wouldn't even know where to start....
Old Sep 10, 2002 | 09:01 PM
FifthGearOnline's Avatar
Default Re: speedodometer problem (dogpile5)
check the speedo wire in the back it may not be fully inserted....i beliege its the white and blue wire
Old Sep 10, 2002 | 10:26 PM
Evil_Wizard's Avatar
Default Re: speedodometer problem (FifthGearOnline.com)
Something isnt hooked up right. I have a gsr dash and type r cluster in my 92 SI and mine works perfectly.
Old Sep 11, 2002 | 01:13 PM
CoolKat's Avatar
Default Re: speedodometer problem (Extreme_Hybrid_Hatch)
i beleive there was somethign wrong with it before i swapped the dash and cluster in. sometimes the speedo wouldnt work and some times it would. im gonna check the iunstall all over again .
Old Sep 11, 2002 | 01:14 PM
i have the 3rd gen integra install guide on my website.....check the tech section
Old Sep 11, 2002 | 01:38 PM
fEEsh's Avatar
Although it sounds like a wiring problem, there is a possibility that it could be a needle and/or needle magnet (i don't know the real name for it). Just my input.
Old Sep 11, 2002 | 02:27 PM
CoolKat's Avatar
Default Re: speedodometer problem (fEEsh)
can some post the wiring diagram cause i cant find mines unless the 6th generation civic have the same wiring. i have the cluster in my 95 civic. maybe the wiring is different but i could be wrong. thanks for replying fellas
Rickdogg
Feb 18, 2012 11:07 PM
K2e2vin
Jan 15, 2008 04:54 PM
CustomX113
Mar 30, 2006 10:09 AM
st0nedstoopid
Jan 20, 2004 05:26 PM
