Rebuilt starter, not starting!!!
Old Apr 21, 2010 | 08:47 AM
cobykai's Avatar
Default Rebuilt starter, not starting!!!
I replaced the contact points in my starter and now when I got to turn the key over, it clicks and you can hear it spinning. But no start.
Ground wire on battery gets very hot.
Old Apr 21, 2010 | 08:59 AM
SoTexDC2's Avatar
Default Re: Rebuilt starter, not starting!!!
Sounds like it's not lined up with the flywheel properly.
Old Apr 21, 2010 | 09:09 AM
cobykai's Avatar
What's the proper procedure to get it lined up?
Old Apr 21, 2010 | 09:16 AM
SoTexDC2's Avatar
If you can hear the starter spinning, but the engine is not, then it's not engaging for some reason. I recall a similar problem a few years ago..
Remove the starter again, and hook it up to a battery just long enough to get the gear to extend. Then, when you reinstall it, line the teeth on the starter gear with the teeth on the flywheel.
Old Apr 21, 2010 | 09:31 AM
cobykai's Avatar
I got the gear extended, reinstalled it back onto the car, amde sure all the grounds were tight and it fired right up.
dmanfree
Jun 21, 2013 12:38 PM
Whiteranger
May 27, 2013 06:39 AM
GoneImport
Feb 18, 2008 06:45 AM
Diablo Tejano
Mar 1, 2005 02:00 PM
ThaSpitefulWun
19
Oct 5, 2004 12:14 PM
