92 Teg, Oil Leak near the Oil pan and lowest Pully.
Old Apr 20, 2010 | 08:32 PM
Fantastic420's Avatar
Default 92 Teg, Oil Leak near the Oil pan and lowest Pully.
I got a leak coming from near the oil pan and the last pulley, where the P/S belt connects to. Very weird, because I just put some new oil and filter in. I started the car and went the gas station, I checked under the car (I like to be on the safe side) and I saw a oil leak. It looks pretty dark.. atleast not the how the new oil i got looks. Its near the Left front under the bay if your sitting in the driver seat facing forward. any ideas?
Old Apr 20, 2010 | 08:35 PM
Default Re: 92 Teg, Oil Leak near the Oil pan and lowest Pully.
I bought the motor a few months ago, not sure what oil it had but replaced with Synthetic 10w30 Castrol. a month later as of today, I put Castrol high mileage 5w30 with a new oil filter. I feel like i needed the castrol 5 30 instead of 10w30 synethic..
Old Apr 21, 2010 | 01:42 PM
When i start the car, there isnt a leak. When it warms up, it starts leaking. When it turn it off, it stops but just the remainder leaks..
Old Apr 21, 2010 | 02:21 PM
its leaking pretty good. I got some oil splattered everywhere. under the hood in the corner by clutch resoivr side. got oil on some hoses. Under the car its leaking almost in 3-4 spots and theyre spreaded. ?
1. I didnt leave my oil filter loose or had 2 gaskets, thats all fine and that area is dry.
2. Oil cap is tight ofcourse.
3. There is nothing i did wrong, what i did was all secured and good to go.
Old Apr 21, 2010 | 03:27 PM
92civic_hatch's Avatar
is it leaking down the back of the block or from the oil pan gasket area?
you prolly put in a lighter weight oil and it sprung a leak on your oil pan gasket seal area
Old Apr 21, 2010 | 03:35 PM
Its leaking from the Driver side mount to down oil pan. It sputters on the clutch resvoir, hood and little on the windshield. I went from 10w30 Castrol Synethic to 5w30 Castrol high mileage. I got 21xxxx. My Oil level doesnt change but still leaks, the more the car's running the more oil it leaks. Its got the Power steering belt oiled up, the altenator oiled up. Couple other spots in that firewall corner by the clutch resoivr.
Old Apr 21, 2010 | 03:43 PM
jimmy o.'s Avatar
camshaft seals or crank seal and switch back to convention oil and not high mileage or synthetic
Old Apr 21, 2010 | 03:48 PM
I have a aftermarket camseal. So it is because I went from 1030 synethic to 5w30 high mileage. Both were Castrol gtx.
Old Apr 21, 2010 | 03:52 PM
jimmy o.'s Avatar
the camseals behind the cam gears....
Old Apr 21, 2010 | 03:53 PM
Im gonna remove my covers and see if i see anything.
Old Apr 21, 2010 | 04:58 PM
Ok, I removed the cover and saw oil all up in there. On timing belt, gears, and lower. Pretty sure its my Cam Gears seals. cost about 15 bucks shipped on Acuraautomotiveparts.
can anyone confirm in a experienced opinion?
Old Apr 22, 2010 | 12:34 PM
if theres oil all behind the cam gears, then that is just about the only place it can leak from there on the head.
switch back to your original oil and replace your cam gear seals
Old Apr 23, 2010 | 09:44 AM
jimmy o.'s Avatar
and replace your timing belt too since it got oil on it and while your at it you might as well get a new front seal too..... just a little preventative manteince
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
pjr710
Feb 6, 2009 10:23 AM
lanojp1
Sep 2, 2004 04:00 PM
Campee
16
May 20, 2003 05:33 PM
