Speakers cutting out when turning
Old Apr 19, 2010 | 07:02 PM
Stryker916's Avatar
Default Speakers cutting out when turning
I have had this problem for awhile now and I can't figure it out.
When ever I turn left my speakers cut out. They also tend to fade in an out depending on how fast/hard I am turning. (ex. No problem changing lanes). If I drive straight or turn right there is no problem.
Now this is the strange part. This only happens when the car is moving. If I am parked I can turn the wheel left and right as hard as I can and there is no problem. If I begin to move the speakers cut out. Again it depends on how fast I am going. It doesn't happen if I going 5-10 mph. Only in the normal driving range of 20-50mph.
I was just curious if anyone else has had this problem or something similar. Any help would be greatly appreciated.
Old Apr 20, 2010 | 04:38 AM
autoluder's Avatar
Default Re: Speakers cutting out when turning
are your speaker wires dangling over the steering shaft into the firewall?
Old Apr 20, 2010 | 06:59 AM
X-bb4lude-X's Avatar
sounds like a connection issue.
Old Apr 20, 2010 | 06:29 PM
BlackCatt's Avatar
^ x2. I would start by checking all connections
behind the head unit, see if that fixes the prob.
Old Apr 20, 2010 | 06:50 PM
twiztid00002's Avatar
^x3
use solder and not that ghetto electical tape
Old Apr 20, 2010 | 10:49 PM
Stryker916's Avatar
That was my first thought, but I figured the speakers would cut out no matter if the car was moving or not.
Originally Posted by twiztid00002
^x3
They are soldered.
I fixed the problem. My drivers side front speaker was causing a short. I removed it and have had no problem since. I'm still confused on why one speaker going out would cause the rest to fail though.
Old Apr 20, 2010 | 11:00 PM
BlackCatt's Avatar
At least its sorted now. Shorts in speaker circuits
can cause weird effects just like you had.
Old Apr 22, 2010 | 10:49 AM
gstrudler's Avatar
Could be some kind of protection in the headunit if the speaker was shorting to itself as to not cause an overload situation on the internal amp. That would also explain why it would "fade" out, if it has a small cap or something in it.
gerardoveracru
Audio / Security / Video
Sep 3, 2015 05:11 AM
TRAG
Honda Civic (2006 - 2015)
Feb 16, 2009 02:27 PM
pl8rzclub
Sep 24, 2007 04:04 PM
flashcivic
Apr 29, 2007 09:03 AM
vinuneuro
Jun 23, 2006 06:24 PM
