Odd PING issues - pls read
D16a6 CRX SI motor in my 4dr ef dx.
Bought a CRX with this motor in it, so when I swapped the motor in the CRX this old SI motor I put in my daily driver since it was a slow dx and burned oil.
Ran good for almost a whole year.
really strong motor, very fast for what it is.
About a month ago I was driving at night and I noticed some pinging when under full throttle and low revs.
Last night was the same thing, so today i got a timing light and set the timing, it actually was slightly retarded.
So I set the ign timing to stock 18 deg or whatever.
Then I went to test it out tonight again, and as you would expect, its the same if not worse.
What the problem is:
Second gear from a slow roll, floor the throttle, kinda like a dyno pull, from 1k-2k revs its ok and 2k-2500 I hear a ping, then 2600-5k+ it sounds fine.
Sounds like it goes away after 2500rpm~
So what could that be?
What could be causing a ping under full load but only at low rpms?
Even when the timing is bang on?
Suggestions please.
Could I have skipped a tooth on the belt and the timing appears to be ok but its really out by a full tooth?
The motor feels really strong, so that makes me think it could be advanced a tooth.
Tomorrow I'll pull off the belt cover and check the cam timing.
Suggestions please.
CIVIC96DXcp
Jul 4, 2005 01:22 PM
Teluan
Aug 29, 2001 10:59 AM
