back pressure hollowed cat
Old Apr 17, 2010 | 07:16 PM
mayfly's Avatar
Default back pressure hollowed cat
ok so i have two cats. one is a high flow magnaflow. other is a hollowed out cat. question is, does a hollowed out cat give incorrect back pressure? and is it harmful for a engine? thanks.
Old Apr 18, 2010 | 04:25 AM
Jenkinsal2's Avatar
Default Re: back pressure hollowed cat
an engine doesnt need backpressure this is a common myth spread about by the "slow" people on forums. What you are worried about however is the exhaust air velocity. The air velocity will change inversely with area. (AKA larger exhaust=larger area=slower exhaust velocity). This is what attributes to the feeling of a loss of low end power or torque after a 3 inch exhaust is bolted up to your stock civic motor.
Truthfully, you will not notice a difference other then sound between your two options so I would say go with the magnaflow and not have to worry about having a loud annoying exhaust.
Old Apr 18, 2010 | 10:49 AM
mayfly's Avatar
good point. ill slap the magnaflow back on. another question. how does a exhaust leak in any area of the exhaust hurt an engine?
Old Apr 18, 2010 | 04:43 PM
D16SiHatch's Avatar
other than the annoying noise a small exhaust leak will not negatively impact your engine or it's performance
4dr_Noob
19
Aug 19, 2012 11:45 PM
user 98292739
Feb 16, 2005 08:12 AM
Nextelbuddy
14
May 16, 2003 09:31 AM
B18C-RnVA
Jul 10, 2002 09:47 PM
