'99 Accord 100k miles: hesitates to rev up from idle
Old Apr 17, 2010 | 12:37 PM
Dannyvho's Avatar
Default '99 Accord 100k miles: hesitates to rev up from idle
I am having the following problem with my F18B2: while the engine is warming up it has a slight hesitation to rev up from idle: as soon as a touch the gas pedal it nearly stalls at first but then starts to rev up normlly after a second or so.
Just after the engine is cold started (high idle) or with the engine already warmed up there is no problem. It just occurs while the engine is warming up.
Automatic gearbox in neutral or in drive makes no difference.
Following has been done:
IACV and throttle body cleaned
Valve clearance adjusted
New spark plugs/air filter
PCV valve replaced
New coolant fluid (done by dealer)
ECU reset
The idle speed is ok: checked both with and without load.
Thanks for your help.
Old Apr 17, 2010 | 02:48 PM
avio's Avatar
Default Re: '99 Accord 100k miles: hesitates to rev up from idle
engine wires? fuel pump?
mwb928
Aug 18, 2015 01:21 PM
mwb928
Aug 14, 2015 10:55 PM
Linked
Jul 24, 2010 07:54 PM
benms79
Classic Hondas
Aug 3, 2008 10:23 AM
Honda_Accord_Type_R
Dec 9, 2005 08:17 AM
