Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake rotor recommendations?
Old Sep 10, 2002 | 02:05 PM
stevecockrill's Avatar
Default Brake rotor recommendations?
Apologies for the cross-post (also in EG forum), but seems like a lot of the smart people reside over here. Anyway......
Just like it sounds. I'd like to hear your opinions and/or experiences. I'm looking at stock sized ones right now. The car is/will be used for street/autoX with the possibility of some lapping, but that's not in the picture for the moment. I've got Axxis Ultimates front and rear on the way from Andie at Cobalt.
I had cross drilled Brembos (stock sized) on my old car, and with Axxis Metal masters they were really nice. I had no problems with cracking at all.
So what do you guys recommend? Blanks? Slotted? Drilled? Both? Dimpled? Does the brand make a huge difference? I mean, APC doesn't make rotors (do they? )......
TIA!
Steve
P.S. Car is a 93 del Sol Si (4 wheel disc) w/99 Civic Si front brakes (10.3" rotor)
Old Sep 10, 2002 | 02:08 PM
Mike P.'s Avatar
25 Year Member
Default Re: Brake rotor recommendations? (stevecockrill)
Blanks will do the trick just fine. Folks here use NAPA, Autozone, Brembo, OEM rotors with very few problems with any of them.
Old Sep 10, 2002 | 02:09 PM
Drew M's Avatar
New User
Slotting/Crossdrilling weakens the rotor. This has been proven. I doubt you will see a problem on the street and probably not in an autocross situation but track duty can crack them. Rotors, pads and tires are all consumables. Stick with the cheapest blanks you can find and just burn them up. Most of the racers here do just that.
Here is about the most thorough thrashing of the subject I have ever seen. 30 pages worth of blingers arguing with racers. You make the call . . .
http://corner-carvers.com/altimathread.php.html
Old Sep 10, 2002 | 02:21 PM
bulldog_RS20's Avatar
Default Re: Brake rotor recommendations? (Drew M)
Autozone. $19.00. nuff said.
Old Sep 10, 2002 | 02:35 PM
Default Re: Brake rotor recommendations? (bulldog_RS20)
Ok, thanks for the responses. I figured that machining the rotor would weaken it for "heavy duty use". I guess most likely I'll maintain the stock sized rotors unless fade becomes a serious issue. I take it even a fastbrakes type rotor-only size upgrade (to 11" or so) is unnecessary on the street? Just the rotor, not the caliper.....
Is there a difference (quality, durability, etc) between the various "autozone" brands - the prices range pretty widely from under $25 to over $75. Is there a reason for this?
Thanks
Steve
Old Sep 10, 2002 | 02:44 PM
johng's Avatar
Really? I get the OE replacements from NAPA at like $24.00 each. I guess I'll have to find a Autozone around here.
You'll find out soon enough that rotors are disposable. The fancy rotors make no difference for the average car. Get OE blanks from a parts house like NAPA or Autozone for cheaper, or spend the extra money and buy from the dealer.
Old Sep 10, 2002 | 08:37 PM
tylerdurden's Avatar
Default Re: Brake rotor recommendations? (johng)
So Brembo OE blanks aren't worth the extra money? I've heard they stand up to an aggressive street pad better (but I'm ignorant, so learn me).
Old Sep 10, 2002 | 10:40 PM
Mojo-Jojo's Avatar
Default Re: Brake rotor recommendations? (tylerdurden)
It seems that they may be worth the money, depending on how quickly you burn them up.
If you're going to burn them up really fast no matter what, probably better to buy two sets of OEM rotors than one set of Brembo OE's even if the Brembo ones would last say...one event longer.
You're still going to need to replace them eventually, so just get the least expensive ones that do the job.
[Edit]
Actually...I was just looking at rotors on http://www.thepartsbin.com
The Brembo OE blanks are cheaper than the other OE replacements.
Ignore what I said above.
[Modified by Mojo-Jojo, 8:02 AM 9/11/2002]
Old Sep 11, 2002 | 09:14 AM
ITC Racer's Avatar
Default Re: Brake rotor recommendations? (Mojo-Jojo)
I guess considering what could happen if a rotor fails on track (ITC CRX being a slow car still gets moving), I run OEM Honda rotors with my Hawk Blues.
While I may try Brembo OEMs, I will not run Napa, Autozone, etc on a race car. While there may not be a difference, I will not take the chance...
There has got to be a reason for the price difference other than markup. Honda buys rotors by the truckload so the cost has got to be pretty low compared to NAPA, etc.
Old Sep 11, 2002 | 09:34 AM
Mojo-Jojo's Avatar
Default Re: Brake rotor recommendations? (ITC Racer)
**** man, I wouldn't want a rotor to fail at any speed, under any conditions, 20 or 120. Let alone in the middle of an autocross or track time, or god forbid, traffic.
Old Sep 11, 2002 | 10:59 AM
johng's Avatar
Rotors from the Honda dealer are more than double what the NAPA rotors are. I have not had any problems with the NAPA stuff to date, other than normal wear from track abuse. I agree that Honda parts are superior and I use OE Honda parts wherever and whenever I can, but since rotors are throw away items, I choose to save money there.
$.02
Old Sep 11, 2002 | 11:11 AM
DOHC-DX's Avatar
try summitracing.com, i believe they have brembo blanks for around $30
brembo blanks are FAR higher quality than the autozone $19 rotors. i've used both and the quality difference is plainly obvious
Old Sep 15, 2002 | 11:56 PM
SpoonSportsJunkie's Avatar
Default Re: Brake rotor recommendations? (DOHC-DX)
I am running Brembo Oem rotors on my eg hatch w/ nissin pads (upgraded from stock I hear) and that is an effective setup.
Old Sep 16, 2002 | 01:28 AM
Kamin's Avatar
Default Re: Brake rotor recommendations? (SpoonFanatic)
brembo blanks with axxis ultimate pads and ate superblue fluid
it stops like a champ.
Old Sep 16, 2002 | 01:22 PM
siisgood00's Avatar
New User
Default Re: Brake rotor recommendations? (KAMiN)
Ultimates, Ate with autozone $26 rotors. Rotors are sweet.
BTW, for the person who said they were worried about a rotor failing in traffic,,, huh?!?
Another_Si_Guy
Feb 6, 2015 12:26 AM
solfire
Dec 31, 2008 01:54 PM
thaseint
Suspension & Brakes
May 1, 2007 09:45 PM
BoostinEJ1
Jun 25, 2004 07:05 AM
stevecockrill
14
Sep 13, 2002 09:53 AM
