Classic Hondas All Pre-1988 Hondas.
my 87 CRX Si has an issue
Old Apr 16, 2010 | 09:35 PM
Gabe87CRX's Avatar
Icon3 my 87 CRX Si has an issue
Well... I just bought it... test drove it on bad gas and ran the tank dry...
SO, added gas... no start... pulled off intake hose, sprayed in TB Cleaner, fires up... runs for about 10 seconds, gets up to about 2k on the RPM's, dies.
Fuel Prime Light comes on... I can hear the pump buzz...
Pulled Fuel line off the filter tried to prime then crank, no fuel comes out....
Safe to say I merked that fuel pump???
I am in the midst of replacing the pump... just wanted some other suggestions...
Old Apr 17, 2010 | 10:18 AM
1grex's Avatar
Default Re: my 87 CRX Si has an issue
No fuel flow. Still not enough in the tank, trash in the supply line, in-tank sock filter clogged... The pump may be bad, but I've run mine dry a couple times with no consequences, and for the most part, if these pumps are on, they are working
Old Apr 17, 2010 | 06:32 PM
vtecn8ive's Avatar
Fuel pumps are easy on these cars. They are inline fuel pumps. Check to make sure your fuel pump is even getting voltage.
Old Apr 18, 2010 | 09:47 PM
Gabe87CRX's Avatar
It was deff the fuel pump. switched it out and it fired like a charm...
5honda
Sep 28, 2018 10:17 PM
jastonian106
Feb 28, 2015 09:03 PM
pr3lude1992
Feb 18, 2009 06:30 PM
EKSedAndy
Nov 12, 2007 10:22 AM
IAteg
Nov 11, 2005 12:34 PM
