89 crx fuel pump questions
Old Sep 24, 2018 | 04:22 PM
5honda's Avatar
Default 89 crx fuel pump questions
is there a priming procedure. it was sitting for a few months with empty tank and filter removed. replaced both. i here it working, but not starting. i removed lines and its coming out slow. should it be coming out with force? figured id ask if anyone has any info
Old Sep 24, 2018 | 08:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 89 crx fuel pump questions
Multiple possibilities... improper installation of the fuel pump, bad fuel pump, split or loose primary fuel hose, or clogged fuel filter just to name a few... it should be coming out with force. Make sure you have at least a half tank of fuel. Priming should only take a few key cycles... like five to ten if everything is operating properly.
Old Sep 26, 2018 | 06:35 PM
5honda's Avatar
thanks for the reply. ill try adding fuel
Old Sep 28, 2018 | 10:17 PM
5honda's Avatar
Was the gas level. thanks for the heads up. i got a 12$ fuel pump off ebay, so i only put a little over 3 gallons in in case it didnt work and i had to take it out. wasn't enough. never actually had to replace 88-91. only 96+, so im use to not having to drain or drop tank..
sasinorm01
Mar 19, 2015 09:28 AM
Gabe87CRX
Classic Hondas
Apr 18, 2010 09:47 PM
646EG
Jan 16, 2008 09:30 PM
shift6
Sep 7, 2004 09:39 PM
