Omni Drag Differences?
Old Apr 15, 2010 | 09:45 PM
Boosted_B_Series's Avatar
Default Omni Drag Differences?
I have two sets of omni drags and they are very different, any incite on this? I'm concerned with the smaller rear shock body on the black set.
Springs are both 18k/12k, one set has skunk2 18k rears instead of omni springs, they actually look thicker [black set]
Thanks for your business and time,
DK
Old Apr 15, 2010 | 10:27 PM
01DC4's Avatar
Default Re: Omni Drag Differences?
Sell me the volks haha.
Old Apr 15, 2010 | 11:37 PM
Haha, na I can't do that brother
Old Apr 16, 2010 | 03:04 AM
littlebluecrx's Avatar
DK
do you have 2 whole sets, or 2 different batch half set's that make a whole? if you have to complete sets ie" 8 total sruts, then keep each batch together. I am sure over the years omni power may have used different manufacturers for his products.... the only issue I could see is the valving be a slight bit different since the actualy shock body is physically different, unless the internal size and valving is identical. Probaly only omni man knows that on here....
Old Apr 16, 2010 | 10:00 PM
I have 8 shocks total, 2 different complete sets, I just used these for pictures.
I just wonder which I should use.
Old Apr 19, 2010 | 06:40 AM
bump
Old Apr 19, 2010 | 07:01 AM
narfdanarf's Avatar
eeny meeny miney mo and sell me whatever set that's left! hhaha
Old Apr 19, 2010 | 07:52 AM
tepid1's Avatar
From what I understand.... the larger bodied assembly is the preferred setup. Valving is better for the aggressive spring rates and rebound has been tuned better from the earlier versions.
The diameter of the shaft is bigger on the newer ones meaning it's stronger. It's best to use the big shaft with heavy springs.
Old Apr 19, 2010 | 09:39 AM
haha, I wish I could brother but I got these for my dc and a ek hatch that I am building for my girlfriend. We would have bought the blox's but they were back ordered so we swooped these up used.
Thanks for the excellent info Tepid!
I think they will both work out fine but Ill use the bigger ones on my black car. One of these sets were pulled off a 1.54 sixty foot car and other set pulled off a 9 sec car so I think we are good.
I tuned a local car on the blox's, makes 18psi on the line and hooks 21 psi in first on a piston rod 35r gsr. Sold me on the drag suspension as I have never been able to put down anything more than wastegate boost in 1st at the track.
Old Apr 19, 2010 | 04:02 PM
Mr. Em1's Avatar
def go with the newer style, the old ones tend to blow out easily
Old Apr 20, 2010 | 11:16 PM
Thanks bud!
Old Apr 21, 2010 | 04:51 AM
turbotypeR@SPEC's Avatar
25 Year Member
Wow, those look familiar! LOL
Old Apr 21, 2010 | 06:02 AM
ATYPR's Avatar
btw, you shouldn't use stock honda ball seat lugnuts with aftermaket wheels
Old Apr 21, 2010 | 10:41 AM
Haha, not sure which set was yours, but thanks for the business
Interesting, we've done this for years, our open ended lug nuts for extended studs seem to have the same tapered pitch/bevel as the lugs pictured, what should we use?
Thanks everyone for their time,
DK
Old Apr 21, 2010 | 02:16 PM
25 Year Member
Mine were the newer larger design.
xthreetwosevenx
Suspension & Brakes
Jun 24, 2006 04:23 PM
WH0R3nEF9
Mar 25, 2005 02:07 PM
dunkd
Aug 27, 2004 12:02 AM
whitelightnin
10
Apr 12, 2004 07:11 AM
