HELPPP unknown integra cam...
ok, im building a b20 vtec motor using a b16a head and a b20b bottom end, ive purchased some cams from a private seller but he claimed they were aftermarket, they have the 3 pertruding lines on the top of the cam simular to b17 gsr cams, but ive taken them to a machine building shop and the guy measured the lift of the cams to be 270, and 290, not sure which number is intake and which number is exhaust (he didnt have a machine to measure the durations), but he said its quite simular to a itr cam, could it be possible for a gsr cam to have the same lift as an itr cam??? it is engraved "HP" at the end of each cam if that helps any....
JDM ITR
Intake lift
11.5 mm
Intake Duration
240 @ 1mm
Exhaust lift
10.5 mm
Exhaust Duration
235 @ 1mm
USDM ITR
1997-1999 ITR
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
Intake lift
11.5 mm
Intake Duration
240 @ 1mm
Exhaust lift
10.5 mm
Exhaust Duration
235 @ 1mm
USDM ITR
1997-1999 ITR
2000-2001 ITR
TurboJdmEF9
May 26, 2006 02:16 PM
customx_
Jan 27, 2002 10:14 AM
