Getting no spark
just picked up a 94 integra (auto thought
.....) for 300. car sat most of winter
i got it and bought a new dizzy, spark plugs, and wires.. still nothing.. totally lost on this one..
car turns over fine and just doesnt wanna start
.....) for 300. car sat most of winter i got it and bought a new dizzy, spark plugs, and wires.. still nothing.. totally lost on this one..
Why did you buy a complete distributor? Where did you get it? Was it new OEM, new aftermarket, used from a salvage yard, remanufactured . . . ? What did it come with? Coil, ignitor, cap and rotor?
Does the Check Engine light illuminate for two seconds and then shut off when you turn the key to position II ("on")? Has anyone been dickering with the engine wiring harness?
brand new dizzy everything included, spark plugs are correct ecu is fine, harness is fine. no other problems with any electrical... just no spark..
where exactly is the main relay at?
i changed it out of a 95 integra (friends car) so i knew it worked...
still nothing, but i did find that the screw that hold the rotor button on is missing... do u need that screw? could it be the problem? i tried to research and i got nothing
I agree, do a spark test first to make sure you aren't getting spark.. if you got a new dizzy, then, you shouldn't be missing anything from rotor... did you just get a cap??..
. i've been through 2 dizzys on my teg.. very common..
