Check Engine Light
I know this has come up a million and one times before, but I couldn't find a thread with my symtoms. Here's what happened.
I was taking an Onramp pretty quickly this morning and as I exited the apex, my check engine light came on. I curised on the highway at 100 km/h. When I got off of the highway and came to a stop, my car wasn't jittering like bent valve symtoms. Any idea on what caused this error code?
I'm going to try to find a tutorial on how to pull the error code from my ECU. Any leads would be appreciated.
Thanks!
Thanks!
to pull the error code: on the passneger side behind the kick panel is a green squishy kind of box looking thing..inside is a small blue plug, pull that out< wont turn anything off, green thing just a protector> then get a paper clip and unravel it, take the 2 ends and put one end in each hole of the plug to "jump it" then turn you ignition to the position right before you start your car, it should flash for you now...
for pics..
http://www.bseries.net/html/garage/engcode.php
-Dave, who knows that URL by heart cause he typed it in so many times on HT
