Unbolting the transmission?
Old Sep 10, 2002 | 11:37 AM
Jeff_G's Avatar
Default Unbolting the transmission?
I have a complete D16Z6 engine in my patio, and i plan on selling the hydraulic transmission, because it wont work in my crx. How do i go about removing the tranny from the long block?
Old Sep 10, 2002 | 12:36 PM
twitchm80's Avatar
Default Re: Unbolting the transmission? (Jeff_G)
Umm... really no way of explain it, well...at least, get a chiltons, or helm, you will need it later anyway.
Old Sep 10, 2002 | 01:00 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
There's a bunch of bolts. Find a ratchet and a socket or two and go at it.
Old Sep 10, 2002 | 01:14 PM
JV's Avatar
JV
Who?
Default Re: Unbolting the transmission? (SkyeC)
If memory serves me. It's just a bunch of 17mm bolts that should be easily accessed with a ratchet and extension...
Just make sure you have got all of them off before you start prying at it...
Old Sep 10, 2002 | 03:36 PM
Slurp56's Avatar
Default Re: Unbolting the transmission? (JV)
Remove the starter/reverse light wires/anything else connected.
should be 4 bolts around the top and front of the tranny on the tranny side.
should be 1 more down low on the back on the engine side.
pull straight out.
Going to need 12point sockets to remove the pressure plate and flywheel.
Old Sep 10, 2002 | 03:49 PM
AllMotorHB's Avatar
Default Re: Unbolting the transmission? (twitchm80)
haha
Old Sep 12, 2002 | 10:54 AM
JOEBLAZE78's Avatar
Default Re: Unbolting the transmission? (AllMotorHB)
Easy just take off the starter and the 17mm bolts also the 12mm bolts on the brakets that hold the engine and tranny i dont know what there called and just pull it off.
navin
Mar 26, 2019 11:14 AM
petty$rep
Oct 6, 2006 01:18 PM
Ben_si
10
May 3, 2005 08:33 AM
SuperDuude
10
Jul 1, 2004 09:24 AM
madhatch
Sep 8, 2002 05:08 PM
