Unbolting the transmission?
I have a complete D16Z6 engine in my patio, and i plan on selling the hydraulic transmission, because it wont work in my crx. How do i go about removing the tranny from the long block?
Re: Unbolting the transmission? (Jeff_G)
Umm... really no way of explain it, well...at least, get a chiltons, or helm, you will need it later anyway.
Re: Unbolting the transmission? (SkyeC)
If memory serves me. It's just a bunch of 17mm bolts that should be easily accessed with a ratchet and extension...
Just make sure you have got all of them off before you start prying at it...
Re: Unbolting the transmission? (JV)
Remove the starter/reverse light wires/anything else connected.
should be 4 bolts around the top and front of the tranny on the tranny side.
should be 1 more down low on the back on the engine side.
pull straight out.
Going to need 12point sockets to remove the pressure plate and flywheel.
pull straight out.
Re: Unbolting the transmission? (twitchm80)
Re: Unbolting the transmission? (AllMotorHB)
Easy just take off the starter and the 17mm bolts also the 12mm bolts on the brakets that hold the engine and tranny i dont know what there called and just pull it off.
SuperDuude
10
07-01-2004 09:24 AM
