b16a idle prob...
Old Apr 14, 2010 | 05:28 PM
speedfreak44's Avatar
Default b16a idle prob...
its an jdm eg9 b16a ob1 ,
issue car sometimes idle at low rpms like 500, 400 even sometimes at 200 or less. at times when turn the steering wheel at idle at a car park etc it will cut off...
i am thinking its the iacv??? if so how to clean/service it... any guidelines ,or other discussed forums... thanks
Old Apr 14, 2010 | 06:17 PM
SolAddiction206's Avatar
Default Re: b16a idle prob...
just remove it and spray some carb cleaner in there. let it dry off and repeat if you are not satisfied. another thing is check your fitv, the screw might have came loose. last thing is your tps may cause idle fluctuations.
Old Apr 14, 2010 | 06:24 PM
ok thanks man... will try the iacv first... will let u kno
Old Apr 14, 2010 | 06:28 PM
tuck1crx's Avatar
make sure u let it dry very well or ur motor will be under the impression it is getting a ton of fuel and idle low or not at all
Old Apr 14, 2010 | 06:36 PM
will do... thanks
apbtwhiskey
Mar 20, 2013 09:39 PM
t-del28
Apr 17, 2011 10:47 AM
4g4me
Jun 24, 2003 01:51 PM
raene
Apr 11, 2003 07:12 AM
