Cam Shaft Position Sensor CEL .. How Do I fix it ?
I am having the Cam Shaft Position sensor code pop up as soon as I start the car up . The dizzy was replaced a few weeks ago . Anything I should check/replace ? I have no idea where to go to fix this CEL.
That sensor is part of the distributor. It can be tested by checking the resistance across its wires coming out of the dizzy. You'll also want to test the resistance of the its circuits leading to the ECU and check the valve timing.
90RENOsedan
Dec 21, 2009 10:14 PM
SiRndX
Feb 28, 2007 06:30 PM
