Hamp oil filters
Old Apr 14, 2010 | 01:20 PM
ITR_1211's Avatar
Default Hamp oil filters
Short of going to Japan, does anyone know of any vendors in North America that are able to get the toyo roki Hamp oil filters (made in Japan). I'm not interested in the tennex Hamp oil filters (made in US).
TIA
Old Apr 14, 2010 | 01:34 PM
get RIGHT's Avatar
Default Re: Hamp oil filters
ICB/jdmland sells them in 5 packs for $39. Support Matt at ICB.
http://jdmland.com/
Old Apr 14, 2010 | 02:00 PM
JDM_nUt's Avatar
Old Apr 14, 2010 | 02:25 PM
ITR_1211's Avatar
Sweet, thanks!
Old Apr 15, 2010 | 01:13 AM
itrmyke's Avatar
Steve at www.hmotorsonline.com sells them, too.
Last edited by itrmyke; Apr 15, 2010 at 01:49 AM. Reason: added additional post text
Old Apr 15, 2010 | 08:34 AM
triple's Avatar
Get the real JDM ones, steer clear of the HAMP oil filters made in the USA which are simliar to the OEM Honda ones.
H1540-PLC-505 - MADE IN JAPAN
H1540-RTA-505 - MADE IN USA
http://www.argen-topia.com/?p=11
Old Apr 16, 2010 | 07:40 AM
JaDaM's Avatar
Are they really that much better?
Old Apr 16, 2010 | 04:56 PM
slofu's Avatar
Yes. Toyo Roki > Fram.
Old Apr 16, 2010 | 05:17 PM
racebum's Avatar
not quite accurate. the us hamps are made by filtech, at least every single one i have seen has been. the jdm hamps are also a decent filter but ALL of these and oem are made to honda spec. the filtech made usdm filters are generally thought to be better than honeywell but most of that is due to the hatred of fram. every honeywell honda filter i've seen is blue, never green. i've also cut open these and the mobil 1 and k&n. the k&n are the best looking construction wise. from net articles they and mobil 1 also use the same media. at least similar. hamp and oem are basic paper filters.
Old Jun 3, 2010 | 09:06 PM
paradox281's Avatar
Are the Hamp oil filters that much better than the oem filters? I usually just use the oem filter. If it is better, how does it compare to a k&n filter.
Old Jun 3, 2010 | 09:09 PM
racebum's Avatar
k&n will pressurize faster, unsure of filter media as i've never seen a side by side micron test
E-gg's
29
Oct 24, 2005 12:48 PM
Built B16A
Dec 10, 2004 02:31 AM
PrecisionH23a
Nov 17, 2003 02:23 PM
Sticky Tires
Oct 27, 2003 08:01 AM
rasta420
Aug 27, 2003 01:55 PM
