difference between s2k oil filters and regular oem
Old Apr 14, 2010 | 07:28 AM
RACEPAK's Avatar
Default difference between s2k oil filters and regular oem
hi guys
iv been hearing that some pepole use a s2000 on their B,D,H engines, and i want to know whats the benefit of them over regular oem filters.
thanks
Old Apr 14, 2010 | 07:39 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: difference between s2k oil filters and regular oem
Regular OEM filters are made by Filtech, the parent company of Fram. Internally, they are very similar to Fram. The bypass valve comes after the filter (like all Frams), which means that if the filter is clogged badly and the bypass has to be used, the bypassed oil can be contaminated with junk from the filter. The endcaps are made of cardboard (also like all Frams) and may deteriorate during use and get into the oil.
S2K Oil filters are made by a different company, has a better design, and higher quality components. In the S2K filter, the bypass is before the filter, so if it's used, the oil doesn't pick up junk from the filter. The endcaps are made of metal and don't deteriorate into the oil.
http://www.s2ki.com/forums/index.php?showtopic=191911
Personally, I use Wix or Purolator Pure 1.
Old Apr 14, 2010 | 07:44 AM
kaiba's Avatar
I read something about the s2k filter provide more oil pressure. If it's a daily driver just stick with regular OEM.
Old Apr 14, 2010 | 08:39 AM
Red_Army's Avatar
well would it really matter DD or not?
its an oil filter. it filters oil. not like its gonna be 20 bucks more just cuz its an s2k filter.
Old Apr 14, 2010 | 08:47 AM
97twodoor's Avatar
Ya i have heard that as well, but it is 100% wrong. The oil pump is internally regulated, so a filter will in no way increase the pressure. The only way to raise pressure would be to put a stiffer spring in the oil pump pressure release valve, or shim it.
Old Apr 14, 2010 | 10:20 AM
98civdx's Avatar
Master Detailer
^ So inlinefour lies?
Old Apr 14, 2010 | 01:23 PM
97twodoor's Avatar
If thats what they say then yes it does lie.
Old Apr 14, 2010 | 04:33 PM
98civdx's Avatar
Master Detailer
just check and they say to use a k series filter for a bit more psi.
They say- Tip: If you want a bit more oil pressure, you can use the rsx/01 civic filters on your B series engine. We've noticed an increase in oil pressure and less fluctuation during vtec operation.
But i guess they're just full of ****?
Old Apr 14, 2010 | 05:04 PM
SiYouLater's Avatar
Most if not all aftermarket oil filters for the civic's are s2000 sized anyways.
Old Apr 14, 2010 | 07:27 PM
ChRiS_p123's Avatar
they sure are, from what i have noticed anyways,
TurboTeG4
Acura TSX
Dec 11, 2013 12:14 PM
redline870
12
Oct 3, 2008 05:13 PM
EG2Driver
23
Sep 15, 2006 09:22 AM
JDM00SI
Jan 20, 2006 10:58 PM
216.226.142.95:27016
Mar 13, 2003 06:43 PM
