Cel code P0141 how to fix it? help
Old Apr 13, 2010 | 10:35 PM
xKAMILxEK's Avatar
Default Cel code P0141 how to fix it? help
okay so i only have one o2 sensor in my header and just replaced this one today and the code is still on
i dont have the SECOND o2 sensor at all
all i got its just a pipe goin all the way to the muffler
does any one know how to fix this ?
and what do to for this code to be gone ?
plz help
should i get a test pipe and just install the second o2 sensor would it help ?
Old Apr 14, 2010 | 12:33 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Cel code P0141 how to fix it? help
plz help
P0141: O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
You just answered your own question, you'll need to get an O2 simulator or convert to OBD1 or use a catalytic converter with a "sparkplug fouler" with a second O2. And no it'll still throw the code with an O2 sensor in the test pipe.
Old Apr 14, 2010 | 04:11 AM
97twodoor's Avatar
^ What he said. However, you will get a new code if you put in the B1S2 sensor, and just a test pipe. A P0420 (Catalyst system efficiency below threshold)
Old Apr 14, 2010 | 06:04 AM
Jimster480's Avatar
What car do you have? Because you need to have your 2nd O2 sensor considering its OBD2.
Old Apr 14, 2010 | 06:42 AM
xKAMILxEK's Avatar
i got 2000 si and the previous owner of the car removed the second o2 sensor completely so theres nothing
i only got the 1st sensor and i just replaced last night.
Old Apr 14, 2010 | 02:37 PM
Jimster480's Avatar
well ur gonna need to have both or convert to OBD1 or ur code will never go away.
Old Apr 14, 2010 | 09:57 PM
xKAMILxEK's Avatar
i will install a test pipe and put the 2nd sensor in
Old Apr 15, 2010 | 01:24 AM
Technical Hero
it will still throw the code
Old Apr 15, 2010 | 06:51 AM
97twodoor's Avatar
Yep you will still get a code. As I mentioned before, it will be a P0420 catalyst system efficiency below threshold code.
Old Apr 15, 2010 | 08:25 AM
xKAMILxEK's Avatar
okay den what do i need to do ???
not 2 have the code? what to get?
Old Apr 15, 2010 | 08:51 AM
andrewk's Avatar
den dawg u got 2 juss say *** it dawg.
On a more serious note, everyone has already listed the ways to fix the issue. If you could read everyone's posts then that'd help you out.
If you put a catalytic converter and a second o2 on the car the code will go away.
Put a test pipe and a defouler and it'll go away. or convert to obd1 and it'll go away.
Can't put it any simpler.
Old Apr 15, 2010 | 08:52 AM
97twodoor's Avatar
You will need to put a catalytic converter in and mount the B1S2 sensor behind it.
98savage
Jun 15, 2007 09:35 PM
98savage
May 15, 2007 10:33 PM
civichybridb16a
Jul 26, 2001 04:51 PM
4dGSR at work
Jul 26, 2001 01:57 PM
