3 Wire coils for C.O.P.
Old Apr 13, 2010 | 12:53 PM
Turbo Ric's Avatar
Default 3 Wire coils for C.O.P.
Well I am looking for some coils that I can use with the GSR head for the COP setup. However it need to be those with built in igniters or 3 wires.
I have looked and searched but still came up nil. Any leads and or Pics? I think my current setup is just old and instead of replacing it I would like to just upgrade in the process..
Old Apr 13, 2010 | 01:01 PM
tepid1's Avatar
Default Re: 3 Wire coils for C.O.P.
Just curious, but why would it need to have built in ignitors? Don't want to run an external one?
I've personally never seen a 3 wire, but I have seen 2 and 4
Old Apr 13, 2010 | 01:20 PM
Turbo Ric's Avatar
Electromotive EMS
Old Apr 13, 2010 | 01:25 PM
tony1's Avatar
Factory K series coils will work with a plate to mount them to.
Old Apr 13, 2010 | 01:41 PM
Turbo Ric's Avatar
tried those, not enough energy and they get burned out
Old Apr 13, 2010 | 01:49 PM
SuperTwinz's Avatar
Really? What coils are the TD Autoworks Civic using? I heard the Okada Coils are pretty good...
Old Apr 13, 2010 | 02:15 PM
tony1's Avatar
Part of the problem with an inductive setup at high power, you're only going to get so much spark energy. If you burned the coils out, the dwell settings were wrong.
Old Apr 13, 2010 | 02:24 PM
Turbo-charged's Avatar
i dont think dwell is adjustable with electromotive. you either run a waste spark set up with their dfu with the gm coils or the mercruiser coils if you want to run a coil per plug but you still have to use plug wires.
i have 4 of the mercruiser coils sitting around if you want to give those a shot
Old Apr 13, 2010 | 03:55 PM
96 GSR-T's Avatar
I know a few people have used GM LSx Coils, I think they die out around 700hp.... I plan on using a set of K Series Coils with my EPM and a tweak to get the spark needed for about 800-850whp...
Old Apr 13, 2010 | 04:07 PM
crispeed's Avatar
True.
I got best results with S2000 coils. No misfires on one application running upwards of 42psi on E85. I also tried the K coils and they were not as strong for some reason.
Old Apr 13, 2010 | 06:51 PM
boosted hybrid's Avatar
I have had the opposite results, the RSX coils were stronger, and with a boost a spark had enough spark energy for 35-40 psi range.
Old Apr 13, 2010 | 07:51 PM
Ovrbst_T66's Avatar
buddy of mine uses 350z coils,makes over 500whp 25-30 psi.no ignition problems yet.
Old Apr 13, 2010 | 08:26 PM
Turbo Ric's Avatar
I hear the SR20 Coils work great with the system but unfortunately they dont fit in the honda head. I was wondering about the bmw mini coils any one know?
Old Apr 14, 2010 | 04:15 PM
elevatedj32's Avatar
How long are they? The honda j32 motors use a 3 wire coil with ignitor in them. I have plenty of them laying around if you want to give it a try.
Old Apr 14, 2010 | 04:21 PM
tepid1's Avatar
What about the 300m coils?
Old Apr 14, 2010 | 05:08 PM
Turbo Ric's Avatar
I do think the 300m coils will work but I am not sure if it will clear the hood if Install them directly on top.
trbocivic226
Audio / Security / Video
Aug 11, 2012 04:11 AM
turbo-crx
Suspension & Brakes
12
Jan 29, 2009 12:42 PM
kaluwa3
Nov 10, 2007 08:50 AM
Blown90hatcH
Welding / Fabrication
30
Feb 17, 2007 05:16 PM
adictionbass
Aug 13, 2004 07:15 AM
