cluster not working
Old Apr 13, 2010 | 09:41 AM
silverbullet9626's Avatar
Default cluster not working
ok so my friend has a 95 accord ex f22 b1. he changed the heater core and had to remove the whole front dash. now he has put it back together and the cluster doesnt work neither does the turn signals outside the car. he has taken it apart 3 times to check and make sure everything is plugged up correctly and no fuses are blown. i think that it may be a relay gone bad somewhere because he said that a wire had arced what do u guys think.
Old Apr 13, 2010 | 09:56 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: cluster not working
Turn signals look at the hazard switch, if that isn't plugged in or working the signals don't work.
What isn't working in the cluster? Lights? Dials? etc?
Old Apr 13, 2010 | 10:54 AM
the whole damn thing doesnt work we had everything plugged up including the hazard switch
Old Apr 13, 2010 | 11:36 AM
slomofo's Avatar
GDD Member
Ground wires aren't properly grounded.
Old Apr 13, 2010 | 12:20 PM
I agree with the sloooooooooooooooomofo as a good place to start. If nothing is working at all then it's probably an issue with grounding for the harness.
Check the grounds are in their original locations and your friend didn't lop any off or mount them different (like to a painted spot)
And wait, what wire arced where?
Old Apr 13, 2010 | 10:27 PM
not sure witch wire arced or where he did all the work himself and brought it to me cause i have a civic and he thought that i could help but ill have him check the grounds.
Old Apr 14, 2010 | 04:51 AM
Haha, well that's kind of an important thing. See if you can track down what wire sparked up.
Old Apr 20, 2010 | 09:27 AM
it was a wire for the power window he didnt realize the windows quit too but that is fixed cluster still not working
Old May 10, 2010 | 06:59 PM
kd97accord's Avatar
I am also having this issue as well, I was wiring up the reveres lights for the 5 spd swap, and when I was checking the auto connector, the cluster lights dissappeared, all lights and gauges don't work except for the battery light and the blinkers.
Any ideas?
Old May 10, 2010 | 10:55 PM
robcook9's Avatar
Any ideas?
m agreed with him, as its not big issue, but if u can make it understand than its easy
Old May 11, 2010 | 04:32 AM
Any ideas?
What about the dash lights and parking lights?
Check small lights fuse (underhood) and the dimmer controller.
Old May 11, 2010 | 06:40 AM
kd97accord's Avatar
The dimmer switch for the gauges works, and so do the headlights, but the cluster - aside from the indicators and battery light - is still dark.
*edit* small lights fuse and both lighting and dimmer relays are intact
Old May 11, 2010 | 07:27 AM
Not the headlights, just the parking lights.
I'm not sure what you're saying then is not working. If the gauges work? What bulbs are out specifically?
Old May 11, 2010 | 07:34 AM
kd97accord's Avatar
I have no reading from my tach when the car is running, speedo does not read, none of the lights come on right before starting the car (you know when all the lights come on in the cluster, then go out), the switch on the side for controlling the brightness works, park lights work, but now the power windows don't.
Old May 11, 2010 | 08:33 AM
Personally, if your tach and speedo are not working there's a chance you damaged them during the uninstall. I have heard of that happening on numerous occassions.
Any chance you can steal a known working cluster to test?
Old May 11, 2010 | 09:13 AM
kd97accord's Avatar
but here's the odd part, i have been driving around for about a week now, and the gauges were working fine, all lights were operational and had no issue with rev's or speedo, this failure happened last night.
Old May 12, 2010 | 09:26 AM
kd97accord's Avatar
Problem found: ground wire became loose and fell off.
palazuelosva
10
Mar 7, 2011 06:17 AM
2LGSR
Mar 1, 2010 08:45 AM
PGH95EG8
25
Oct 29, 2009 12:10 PM
ridgewayballa
Jul 2, 2008 10:55 AM
dravesef
Jun 19, 2008 03:46 PM
