what do i need to lower my cg5?
i would like to know which is the best brand name to go with when it comes to coilovers/springs?
i have a 2000 honda accord special edition.
thanks
thanks
There is a suspention thread in the FAQ's that you could read over. I'm not sure how up to date it is but it should give you a better idea of what to look for.
https://honda-tech.com/forums/honda-accord-1990-2002-2/basic-guide-accords-797528/
& here is a tread with pictures & specs of members suspention setups.
https://honda-tech.com/zerothread/1971782
Not necessarily. There are different spring rates and different styles of shock that will determine your ride quality. Depends on the combination that you choose.
ok, because this will be my daily driver and i want something im going to be comfortable with but at the same time looks hella dope!
i appreciate the help, man.
time to do some research!
thanks
thanks
I have heard great things about skunk2s springs and coilovers. Progress (i think thats the company) i have heard recommended. D2s are good. Just depends on what you are looking for. Tein is alot of people's default choice for a nice comfortable ride. If this is your DD then you should look into a simpler setup that'll still give you nice handling and low stance.
true enough my man!
im definitely aiming for the simple set-up. i want a clean looking ride that's good for all seasons (Toronto winters and shitty roads).
thanks for the info too, im considering eibach sportline or tein.
needashell1234now
Suspension & Brakes
Jan 27, 2007 11:35 AM
