Close to everheating, radiator fan
Old Apr 12, 2010 | 11:28 AM
Shade93's Avatar
Default Close to everheating, radiator fan
I was in the drive-thru for about ten minutes when I noticed my temperature gauge was HOT. I got out of line and let it sit for a few minutes and started it back up again. It was about halfway this time, and it only would start rising when I was sitting still. I'm thinking the radiator fan isn't kicking on, but could there be anything else to look for?
Old Apr 12, 2010 | 11:41 AM
RICKSAUTOMOTIVE's Avatar
Default Re: Close to everheating, radiator fan
fan switch. at this point pop the hood when its cold. start the car and let it warm up. listen for the fans to come on and watch the temp. check the thermostat too. the fan switch does go out from time to time
Old Apr 12, 2010 | 01:38 PM
Shade93's Avatar
Fan doesn't turn on, temperature gauge keeps rising though.
Old Apr 12, 2010 | 01:52 PM
ej888's Avatar
Exactly my problem and found out it was the coolant temp switch. I would first jump the fan to see if it even works. Next warm up your car and wait for the thermostat to open(you know it has opened when the lower hose is as hot as the top hose) If it opens and your fan doesn't come on within 5-10 sec, it's your coolant temp fan switch.
Old Apr 12, 2010 | 03:03 PM
sloassSi's Avatar
yup. good advice.
Old Apr 12, 2010 | 05:00 PM
Akai Star's Avatar
i have the same problem but my gauge doesn't shoot to the top. it just rises as the engine warms up.(which takes about 10-20mins idling) however my radiator starts to smoke after like 5mins. my fan doesn't turn on but i tested it and it works fine. coolant temp fan switch or coolant temp sensor?
Old Apr 13, 2010 | 10:55 AM
Shade93's Avatar
Me and my dad figured out the problem. We had a test light and found out that the switch wasn't putting out the signal to turn the fan on. Luckily I have my old d-series laying around so I used the plug off of it. Works perfect now. Thanks guys I wouldn't of figured it out with out the advice!
Old Apr 13, 2010 | 11:49 AM
Akai Star's Avatar
which one did you switch out?
Old Apr 13, 2010 | 01:15 PM
D16SiHatch's Avatar
the fan switch on the thermostat housing.
MyRed98Civ
Jan 11, 2014 06:51 PM
jodyboy
12
Aug 15, 2012 09:39 PM
Pure Sol
Apr 20, 2011 04:01 PM
rextec
21
May 17, 2006 05:43 PM
4U2NV
Jun 14, 2004 11:46 AM
