Mixing clutch/flywheel - Quick Q
Old Apr 11, 2010 | 01:32 PM
MHDesigns's Avatar
Default Mixing clutch/flywheel - Quick Q
Ok. So i've never done this. My current clutch is gone, and I cant afford to replace it with the same one. I was gonna just use an exedy oem replacement, since its wallet friendly.
This is my question: My original clutch was a Competition Clutch stage 4 clutch and flywheel combo. Can I use the comp clutch flywheel with the exedy clutch? I ask because most clutch companies suggest to not "mix" brands. Is this just a suggestion... or is it imperative. Thanks in advance for the answer.
If it matters. It's a b18a block and y80 tranny
Old Apr 11, 2010 | 06:14 PM
MHDesigns's Avatar
Default Re: Mixing clutch/flywheel - Quick Q
Bump.
Old Apr 11, 2010 | 07:11 PM
gilbert90605's Avatar
Originally Posted by MHDesigns
Bump.
my exedy stage one instructions just said to replace or resurface the flywheel..
Old Apr 11, 2010 | 07:15 PM
Deetz's Avatar
Crazy Honda Guy
There is nothing wrong with mix and matching product brands
Old Apr 11, 2010 | 07:25 PM
MHDesigns's Avatar
Right on. Thanks guys. I just wanted to be sure before I got it apart.
Old Apr 11, 2010 | 07:46 PM
you know much about starters?
i just changed my clutch today and my starter is acting up.
i went to get a rebuilt one from kragen auto parts and that one
just clicks too..
i havent got a chance to check if it spins when its off the tranny, the sun went down.
Muydos
Apr 6, 2012 05:30 PM
leondx
Apr 5, 2010 06:19 AM
bboysake
Oct 14, 2006 10:13 AM
luvinmyGSR
Jun 17, 2004 08:08 PM
