98 civic b18c5, go to crank all power shuts off.
I was working on trying to figure out another problem and was moving some wires around
when i sparked off the starter with the main power wire for it. stupid me I had forgotten to
discount the battery. anyhow so now when i try and start it, you turn the key everything
comes on gauges and what not. then you turn it to crank the starter and all the power in the
whole car dies.
So the question im asking is, does anyone know off hand if there is a
fuse/relay or similar that could be out and causing this problem ?
whole car dies.
Looked through the fuses in the engine bay fuse box, everything looks good there. When I turn the key all i hear is a click and dash, gauges, fan, etc everything loses power and it doesn't come back when you turn the key back. I have to disconnect the battery.
Other then sparking off that starter the one day I dont think i changed anything in the wiring power or ground.
oneprelude
Apr 26, 2009 08:49 AM
Lude@Heart
10
Jul 27, 2006 04:52 AM
