WENT TO THE 1/8 MILE TODAY
Old Apr 10, 2010 | 08:59 PM
ysofasts2k's Avatar
Default WENT TO THE 1/8 MILE TODAY
HEY GUYS NEED YOUR HELP WASNT ABLE TO MAKE IT TO THE TRACK TODAY SO I WENT TO THE 1/8 MILE, AND HOLLY **** I DID BAD,
CAR MAKES 400 HORSE AND I HAVE 24.5 MT SLICKS ON 13, BOGARTS 2 STEP NOT WORKING FOR SOME REASON
LAUNCHED AT 6500 THE CAR SPIN IT S *** OFF AND WHEN IT HOOKED IT TOOK OFF,,,,TIRES WHERE AT 20 PSI
THEN ON THE SECOND LAUNCH, I LAUNCHED AT ABOUT 7500 WITH TIRES AT 10 PSI THE CAR FELL ON IT FACE AND THEN GOT BACK UP WHEN I SLAMMED SECOND I HEARD POW I SAID ****ING **** MAN MY MOTOR, BUT SADLY THE PASSANGER SIDE AXLE BROKE SADLY,
R/T 0.520
60FT 2.412
TRAP MPH88.4
TIRES WERE AT 20 PSI MT SLICKS 24.5
R/T0.312
60FT 2.403
BROKE AXLE
TIRES WERE AT 10 PSI
LAUNCHED AT 7500 AND BOGGED.
Old Apr 10, 2010 | 10:21 PM
ochocinco's Avatar
Default Re: WENT TO THE 1/8 MILE TODAY
What was Mph first run? You started out really high on the psi with slicks. More track time and you will be rolling. Are you preloading axles?
Old Apr 11, 2010 | 02:16 AM
ysofasts2k's Avatar
yea i was preloadinig the axlex n still not much benefit
Old Apr 11, 2010 | 04:36 AM
inspector01's Avatar
Im no expert, but....
We need more info. What EMS do you have?? are you using launch control/anti-lag?? What chassis/weight?? It sounds like you didn't have enough power off the line if you are bogging when launching at 7.5k.
What engine mounts? you may need stiffer.
Start with the slicks around 10 psi, launch at a high rpm and work your way down till you aren't spinnning and you aren't bogging. Use launch control to try and build a bit of boost (you should be able to make at least 3-5 psi) or even better, anti-lag if you have it.
You should be cutting 1.8s at least, and what were your traps??
Old Apr 11, 2010 | 07:56 AM
GSRswapandslow v2's Avatar
8.3's really really really really slow... that's bolt on all motor area
what was your MPH?
Old Apr 11, 2010 | 09:03 AM
ysofasts2k's Avatar
ok well here is the thing the car is an eg coupe not sure of weight yet,
i figured out a few things so ill check and see what my mistakes are,
i was taking off the line at 7200 but i figure due to not having the 2 step set up is why it fell on its face, so im going to figure it out,
Old Apr 11, 2010 | 01:45 PM
ysofasts2k's Avatar
I found ou thw 2 step wasnt working so im going to run the car again this weekend at a lower tire pressure n with the 2step working, oD
Old Apr 11, 2010 | 06:15 PM
ysofasts2k's Avatar
SOMEONE HELP
Old Apr 11, 2010 | 06:24 PM
92redhatch's Avatar
I trap 98mph at the 1/8 with 400whp on a bad pass.
Old Apr 11, 2010 | 06:41 PM
ysofasts2k's Avatar
o i see, well maybe its traction issues and bad sixty foots what trans u running
Old Apr 11, 2010 | 06:49 PM
i ran 8.3@88 mph all motor, on 185/65/14's..............was an RLZ built 2.1L, but still...i got STOMPED by even the worst driven 400whp in MPH
Old Apr 11, 2010 | 06:56 PM
1grex's Avatar
too much tire pressure
Old Apr 11, 2010 | 07:01 PM
13173's Avatar
With 279whp tuned on RLZ's dyno I was in the mid-high 7's on street tires. These runs were over 90mph and with crappy 60' times. Also, I did not have any antilag or anything with that tune. It was all launching off pedaling and preloading. With closer to 400whp I was around 100mph........these days 400whp can get you low 11's and possibly into the 10's with some practice. You should also run around 100mph with 400whp regardless of 60' times or any 2-step in the 1/8th.
Old Apr 11, 2010 | 07:12 PM
OMG B16's Avatar
1st run, too much tire pressure.
2nd run, you let the clutch out too fast so it bogged hard and most likely hurt your axle there then broke on the hard shift. You need to fix the launch control and work on your clutch control/preload technique.
Old Apr 11, 2010 | 07:16 PM
ysofasts2k's Avatar
car was already preloaded when i staged and i was okay just i guess when i dropped the tire pressure something had to go
fungus mungus
Oct 28, 2011 10:25 PM
BILLY_BLING
Nov 6, 2006 01:17 PM
PM-Performance
Jun 21, 2004 02:33 AM
Jared
May 27, 2002 09:47 AM
HX_Guy
Dec 20, 2001 09:49 AM
