Car won't start 1996 Honda accord lx auto
Old Apr 10, 2010 | 09:09 AM
elnoyl's Avatar
Default Car won't start 1996 Honda accord lx auto
The car won't even turn over. The radio works. I am assuming it's the starter but would like some other things to check for before i dive in and remove it and get it tested.
Old Apr 10, 2010 | 09:34 AM
nsr ek9's Avatar
Default Re: Car won't start 1996 Honda accord lx auto
u can check if its the starter without taking it out have someone crank the car while u test the connector on the starter for power with a test light if power is present its bad. check connector for power not wire with nut. if power is present tap the starter wit a hammer and crank see if it starts if it does the starter was stuck and is bad
Old Apr 10, 2010 | 03:50 PM
Team_Beard's Avatar
If all your accesories come on (ex. radio, dash lights, etc.) but when you attempt to crank they all shut off it could be a ground wire causing you trouble. check all of the engine ground wires to see that they are clean, not rusted, and installed tightly. If dirty; clean. If rusted; replace. If loose; tighten.
Old Apr 10, 2010 | 06:44 PM
elnoyl's Avatar
yeah it's the starter. I tapped the starter and now it works. I'm assuming it will break in the future. Any input?
Old Apr 11, 2010 | 03:39 PM
Team_Beard's Avatar
lol. replace it or keep a hammer in your glove box!
Old Apr 11, 2010 | 04:32 PM
phattsi's Avatar
I'd change it out just for piece of mind. Just think if your in traffic and your car would die, you be out of luck.
Old Apr 11, 2010 | 06:03 PM
djkurious's Avatar
Replace it! The one day you are rushing for work is when the knocking method wouldn't work anymore...
Old Apr 19, 2010 | 07:29 AM
nsr ek9's Avatar
happy my advice helped good luck
Old Apr 19, 2010 | 08:34 AM
siampride's Avatar
coolios
nestea8869
10
Mar 26, 2022 10:12 AM
beco
19
Mar 26, 2022 10:08 AM
Jeannies car
Sep 6, 2015 09:26 AM
Zaxxx20
Jun 23, 2012 06:23 AM
OPTION2ek V.2
Jul 18, 2005 10:05 PM
