new car ??'s
Old Apr 10, 2010 | 08:50 AM
FO SHO's Avatar
Default new car ??'s
hey all im about to be picking up a 95 civic dx. its been sitting in a friends garage for 3-4 years.
my question is about getting the old gas out. my one friend told me to just undo fuel line to fuel filter then make an extension to a gas can then just let the fuel pump drain it all. is this going to to get all the gas out or will i have to drop the fuel tank?
Old Apr 10, 2010 | 09:05 AM
DRoszyk's Avatar
Default Re: new car ??'s
your friends ideal will work but if you want completely 100% of the gas out your going to have to drop the tank and open it up to de-puddle and clean it out. you could just stick a hose down into the tank and siphon the gas out with a hose into a bucket or something like that too.
Old Apr 11, 2010 | 05:49 AM
FO SHO's Avatar
if i do the fuel pump way and dont get 100% of gas out could i just fill it with premium and be ok? or should i just do the hose and bucket thing?
Old Apr 11, 2010 | 01:13 PM
Armychris89's Avatar
There should be a fuel drain plug on the driver side of the tank. Be careful loosening it. You should be able to get most of the gas out. I wouldn't recommend starting the car with the old gas in it because of the gunk that could be inside the tank still. Instead drain all you can and drop the tank and clean it out then fill it up. Take the fuel line off the filter and drain about a gallon into a container. Should be good as new.
Old Apr 11, 2010 | 01:30 PM
FO SHO's Avatar
thanks, that doesnt sound bad. is there a link anyone has to dropping/cleaning a tank? i cant find one.
James Parkhill
Oct 24, 2016 06:15 PM
Randysi
May 15, 2012 06:12 PM
Hondaisok
Sep 27, 2010 09:30 AM
r3v da t3g
Oct 23, 2006 06:37 PM
Hard2Find
Aug 16, 2004 08:47 PM
