Non-Vtec --> Vtec
I have no idea. I imagine one from the vtec solenoid to the computer but im just guessing. A freind of mine told me i need to hook up 2 wires to hook up the vtec. My engine harness is for a non-vtec
you need the two wires to run vtec, the oil pressure and vtec solenoid wires to be exact. i have mine run straight to my ecu. will take a picture if needed but it should be pretty straight forward. your wires will need to be about 3 feet in order to not get snagged on the carpet and still be able to be tucked underneath the carpeting on the passenger side of the car.
any pictures would be great if possible, im mostly concerned about where on the ecu plugs am i supposed to run them to, but pictures of everything would be a big help.
thanks!
thanks!
If you're running a obd1 ecu like a p28 then vtec solenoid gets wired to A4 and vtec pressure switch gets wired to D6 hope this helps sorry no pics right now
im ordering an OBD1 ECU and OBD2->1 conversion harness from phearable.net. thanks for the pics but the diagram says for b-series, im not sure if its the same or not but im building a D16Z6.... and ive already done the 3-wire to 2-wire plug on the engine harness, and im having someone else do the ecu plug before i break something.
MugenHonda
Jan 2, 2006 09:41 PM
xXx Justin xXx
May 13, 2003 07:58 PM
