99 4dr trunk fit on a 96 4dr?
Old Apr 9, 2010 | 09:30 PM
flash69's Avatar
Default 99 4dr trunk fit on a 96 4dr?
Was wondering if a 99 civic trunk would fit onto my 96 4dr civic without any modification?
Old Apr 9, 2010 | 09:59 PM
-__-'s Avatar
Default Re: 99 4dr trunk fit on a 96 4dr?
yes it will fit perfectly. you will need to use the 99/00 tail lights as well though.
people do this all the time because they think that the 2000 rear looks better. to make it look good, you should think about getting the outer lights from a 2000 civic 4 door too.
Old Apr 10, 2010 | 12:14 AM
NOFX's Avatar
H-T White Ops
I believe the trunk itself fits no problem, but I think there is some reason that you might need to do some slight re-wiring.
I know I talked about this with someone else on here once and that's what we figured out.
Old Apr 10, 2010 | 01:05 AM
Ruben19's Avatar
even the acura 1.6el would fit and looks alot better
Old Apr 10, 2010 | 04:57 AM
kcjohnnyboy's Avatar
yes i believe that some rewiring of the tail lights are required cause the light bulb sockets are not the same as the 96-98 compared to the 99-00
Old Apr 11, 2010 | 05:03 PM
-__-'s Avatar
^^this is true.
xxxrabbixxx
Mar 15, 2015 07:33 AM
Failsafe88
12
Sep 29, 2010 05:03 PM
tonytkiddo
10
Mar 24, 2008 02:41 AM
hondamad
Nov 22, 2006 05:15 PM
civic23g
Dec 20, 2002 06:49 AM
