Obd 1 b16 into 2000Ek code 6 help!!!
Old Apr 8, 2010 | 09:45 PM
crx21's Avatar
Default Obd 1 b16 into 2000Ek code 6 help!!!
I got a 200 ek coupe with a obd 1 b16 with obd 2b to obd 1 conversion harness. Keeps throwing code 6 which is coolant temp sensor but I replaced it and still does it and all the wiring is fine and so is the sensor any help or ideas.
Old Apr 9, 2010 | 05:52 AM
xero_xero's Avatar
Default Re: Obd 1 b16 into 2000Ek code 6 help!!!
you need to ohm out the wiring first to check for shorts. ground out your negative to the frame and probe for the coolant temp plug.
quickspool
Jun 26, 2010 06:26 AM
tdubbebawllin
Apr 23, 2009 03:16 PM
6E LUDE
Oct 15, 2005 01:13 PM
baked_beanz
Jul 23, 2005 03:16 PM
90civichbsi
Oct 3, 2002 02:49 PM
